shatzbot10 Posted October 30, 2006 Share Posted October 30, 2006 Can anyone advise me? Is there an easier manual in the offing? Thank you Link to comment
Albert Posted October 30, 2006 Share Posted October 30, 2006 Joe, I agree, the CD manual is just aweful. It's a non-intuitive user interface that is practically imposible to get decent printouts from (no I don't have a PC in my garage). I don't have any real tips for you other than to make sure you run a high enough screen resolution when viewing the manual. If you run a lower resolution it will be difficult to fit the pages onto your monitor screen. As for other sources, I contacted Haynes several months ago to see when they'd be putting out an RT manual for the 05/06 models. They indicated that mid 2007 was probably the soonest they'd have something. Link to comment
shatzbot10 Posted October 31, 2006 Author Share Posted October 31, 2006 Thank you for your quick reply. My problem, however, is that I can't locate particular info. For instance, where do I find, "How to remove cowling to easily replace left low-beam headlight."? Joe Link to comment
Limecreek Posted October 31, 2006 Share Posted October 31, 2006 You need to go to >Lights>Headlights and then click on the repair manual. I'd skip the disassembly and reach up from the front of the bike to change the bulb. Link to comment
shatzbot10 Posted November 1, 2006 Author Share Posted November 1, 2006 Thanks mate. I'l give it a try. Link to comment
