2wheelterry Posted October 29, 2006 Share Posted October 29, 2006 I'm starting a repair of my failed transmission input shaft splines. I've got the transmission out, but could not get the drive shaft off the output shaft of the transmission before I took it out. The BMW manual says to "press off drive shaft." I used some force with a prybar (screwdriver), but it did not budge. There is a picture that is not too much help. I watched the Spline Lube DVD (which was helpful), but their 1100 drive shaft came off with no effort. Is there a trick here? Link to comment
bmwmick Posted October 29, 2006 Share Posted October 29, 2006 I'm starting a repair of my failed transmission input shaft splines. I've got the transmission out, but could not get the drive shaft off the output shaft of the transmission before I took it out. The BMW manual says to "press off drive shaft." I used some force with a prybar (screwdriver), but it did not budge. There is a picture that is not too much help. I watched the Spline Lube DVD (which was helpful), but their 1100 drive shaft came off with no effort. Is there a trick here? Yep, Protect the tranny housing with a heavy rag or something and apply more force to that prybar. I use a medium sized screwdriver to pop them past the c-clip. Mick Link to comment
smiller Posted October 29, 2006 Share Posted October 29, 2006 It also helps if you apply an impulse force rather than steady pressure, i.e. get everything in place and then whack the prybar/screwdriver handle with the palm of your hand. The driveshaft should just pop off the transmission output shaft. Link to comment
2wheelterry Posted October 29, 2006 Author Share Posted October 29, 2006 Got it, thanks to both of you. Link to comment
