aal3 Posted October 21, 2006 Share Posted October 21, 2006 Is the Harley Davidson 20-50 weight oil ok to use in an 1150 RT? Link to comment
Guest Posted October 21, 2006 Share Posted October 21, 2006 Is the Harley Davidson 20-50 weight oil ok to use in an 1150 RT? Yes (above freezing). Link to comment
4wheeldog Posted October 22, 2006 Share Posted October 22, 2006 The engine probably won't mind, but it might make your pipe louder. Link to comment
karlheinz Posted October 22, 2006 Share Posted October 22, 2006 I would not use harley oil even if i had a harley.A friend drained his harley oil to change it when i stuck my fingers into it.Rubbing the oil between my fingers it felt like there was no substance left.Compart to bmw oil wich is made by spectro what a difference. Gave him some of my oil and guess what his lifter down tubes stoped leaking including his valve cover gasket. So there you have it. Link to comment
Bill J Posted October 23, 2006 Share Posted October 23, 2006 ...as a "quick oil question." The type of of people use is an almost religious issue on these boards. FWIW, I buy my oil at Walmart without my bikes grinding to a halt. That's my way of saying HD oil will be fine. Others will disagree. Link to comment
azkaisr Posted October 23, 2006 Share Posted October 23, 2006 ...as a "quick oil question." The type of of people use is an almost religious issue on these boards. FWIW, I buy my oil at Walmart without my bikes grinding to a halt. That's my way of saying HD oil will be fine. Others will disagree. Oh boy now you did it I agree with you though on this issue Kaisr Link to comment
barncobob Posted October 24, 2006 Share Posted October 24, 2006 splurge and get the mobil 1 synthetics motorcycle oil designed for air cooled " v-twins" and others at walmart, its not in the oil section(duh!) its on the next aisle in motorcycles. go figure. i think it was 6.58 qt. Link to comment
