wyldcat Posted September 25, 2006 Share Posted September 25, 2006 while riding my k-bike it has a tendancy for the power to cut out (usually i turn the ignition off and then on again and pwoer has come back)but some times will not come back on even when you turn the ignition completely off and on again in need of help as butget is non excis tant atm Link to comment
PaulCrinson Posted September 25, 2006 Share Posted September 25, 2006 I had an intermitent problem with my K1100RS and believe it was caused by the fuel pipes being caught up or kinked underneath the tank. I could be riding for 4-5 miles and then it would cut out completely. Leave it a while and all would be OK. I took off side panel on left of bike where I could get at pipes and made sure they were clear and have had no problem since. If you've had the tank off or it's been serviced recently I'd check that first. Paul Link to comment
nldaniel Posted September 25, 2006 Share Posted September 25, 2006 when the power cuts out, is the instrument panel working? tach needle etc? noticed any particular circumstances when it happens? like turning, WOT, etc.etc ? from the top of my head, itcould be a problem in the ignition circuit. a simple test would be to turn ignition on. use brakes to turn the red warning light off. wiggle key, wiggle wiring to ignition switch, tap kill switch. if the red warning lights comes on during any of this you found your problem. hth, Daniël Link to comment
thebaldguyis Posted October 10, 2006 Share Posted October 10, 2006 while riding my k-bike it has a tendancy for the power to cut out (usually i turn the ignition off and then on again and pwoer has come back)but some times will not come back on even when you turn the ignition completely off and on again in need of help as butget is non excis tant atm I have experienced the same (i think) issues of late. Last year i bypassed my keyed ignition switch (original quit working) with a toggle. Everything worked fine since, until several weeks ago. At first, I would be idling at a full stop, and all electrical would stop. Engine, instruments, everything, like I had disconnected the battery. I would turn the ignition (toggle) switch off and on until power was restored. Then I could restart and ride forever. Last week, while riding, the power (engine, instruments, lights etc) would cut off briefly, like a millisecond, then come back on. I have checked all connections, checked the toggle switch for problems, and have found nothing out of the ordinary. By the way, it is an '85 KRT. 75,000 miles approx. Any suggestions, I do ALL my own work, and would appriciate any help, as I don't want to lose power in the middle of a nice twisty. Thanks, Mr. Bill Link to comment
Don_Eilenberger Posted October 11, 2006 Share Posted October 11, 2006 while riding my k-bike it has a tendancy for the power to cut out (usually i turn the ignition off and then on again and pwoer has come back)but some times will not come back on even when you turn the ignition completely off and on again Dirty ignition switch. See: http://www.eilenberger.net/K75S/IgnitionSwitch/index.html Link to comment
RFW Posted October 11, 2006 Share Posted October 11, 2006 I have a K100RT that I personally do all the work on, so I am pretty familiar with the bike. Check your kill switch to see if there is an intermittancy. The ignition switch can also be intermittant (mine sometimes acts up). As others have said, look for symptoms, such as which instruments and lights continue to work and which do not. Another inportant clue is whether the brake warning light comes on when the motor cuts back in again. if it does, this implies a problem with power from the ignition switch, or an intermittant kill switch. If the red brake warning light does NOT come on when power is restored, then the problem is not related to an intermittant ignition switchm, of kill switch, and coule possibly be an ignition intermittancy (note that it must be something that affects BOTH ignition coils or BOTH Hall sensors), or possibly a connection that supplies power to the FI system. Link to comment
