CruisinCruzan Posted September 20, 2006 Share Posted September 20, 2006 I've finished my headlight upgrade on my '06 RT replaced the low beams with 4300K HID lights put in an overwattage high beam bulb and then supplemented the high beam with a pair of Hella micro DE HID driving lights mounted under the oil cooler. Don't ask how I know how little space is under there once the suspension compresses with the wheel turned. A half hour with a tape measure, level and my wife to help me tweak the aiming and I took it out for a nighttime ride, well aimed instant sunlight! I wired the lights with an on-off switch that when it is in the on position they are slaved with the high beams (thanks to Ken H for wiring advice). I like lights like a Harley guy likes chrome. I figure with 4 35 watt HID lights I can almost melt the car in front of me if I want to. Next more LEDs mounted to the top case with a quick connect for when I ride without it. Tinkering it never ends! Link to comment
jbargenquast Posted September 21, 2006 Share Posted September 21, 2006 What brand of HID lights did you use and where did you get them? Do you have any pictures? Inquiring minds want to know! Link to comment
Calvin (no socks) Posted September 21, 2006 Share Posted September 21, 2006 Love those Micros.... I have a set on the GT.... I do a lot of night/wee hours riding... with empty roads...wow The guys won't let me ride sweep anymore... I burn their retinas too much.... Link to comment
CruisinCruzan Posted September 21, 2006 Author Share Posted September 21, 2006 I bought a set of xenondepot 4300K lights. Although they have a separate ignitor it is quite small and the ballast is very thin so mounting was not a problem. Everything is wired through a Painless Wiring fuse block. Link to comment
