RTguy Posted September 19, 2006 Share Posted September 19, 2006 I've owned my '98 RT since new. Lately the starter has been making some awful gnashing sounds when I first start the bike. Much worse on cold mornings. Seems to work OK when warmed up. Also, the ABS is very reluctant to set itself. Again, its worse when cold. Old battery maybe? Any help would be appreciated Link to comment
Tony_K Posted September 19, 2006 Share Posted September 19, 2006 Sure test the battery. Anything below 12v is bad. Starter is the most taxing on the electrical system and when batt is low it doesn't engage well. Link to comment
pablo Posted September 19, 2006 Share Posted September 19, 2006 1st check voltage, if ok. Try banging on it with the wooden handle of a hammer during the start, this will release the starter splines to the ring gear if they are sticking. Your starter may be going. How many miles on the bike? Does it catch eventually? Link to comment
Bill Dennes Posted September 24, 2006 Share Posted September 24, 2006 Pull and replace the starter relay under the seat to clean its pins. Easy to do, may help. Link to comment
gusanito Posted September 24, 2006 Share Posted September 24, 2006 Years of eating clutch dust is most likely jamming up the sliding gear on your starter. Disconnect the battery and pull off the starter (2 bolts). Clean it up, put a small amount of grease on the shaft and you should be set to go. As far as the ABS, sounds like you're ready for a new battery. George Link to comment
ogjimbob Posted September 25, 2006 Share Posted September 25, 2006 on mine '97 rt1100, it turned out to be a displaced permnent magnet in the starter! it eventually got chewed up and jammed resulting in a second hand starter being fitted, since which I have had no problems at all with the ABS lights! Link to comment
otis Posted September 25, 2006 Share Posted September 25, 2006 Does the starter make noise after you release the button? Mine was doing this....I lubed the starter gear/shaft and all is quiet now. Link to comment
