maxscycle Posted September 17, 2006 Share Posted September 17, 2006 Any use a throttle rocker device on a r1100rt (or similar). My wife wants to install one on our rt (it already has the euro police style throttle lock screw on top). I am concerned it being a problem using the heated grips with a rocker installed. Any brands of rockers recommended? any brands to shy away from? thanks Link to comment
SpinTurn Posted September 17, 2006 Share Posted September 17, 2006 I have used them on other bikes with no problems, but when I tried one on my 04 RT I kept catching the end of the plastic in my sleeve when braking resulting in unexpected throttle input (not good! ) Bought a Bob's Wrist Rest from Bob's BMW and never used the throttle rocker again. Link to comment
tomk99r11 Posted September 17, 2006 Share Posted September 17, 2006 Go figure. I have a throttle boss on each of my bikes and a Wrist Rest from Bob's on my R1100. I like the throttle boss because it lets you just lay your hand on the grip and vary the grip position to tweek speed with the terrain. I never use the Wrist Rest because it doesn't hold speed (not supposed to though) and you always have to fiddle with it. Just depends on your preference. Link to comment
philbytx Posted September 17, 2006 Share Posted September 17, 2006 Ever considered a Throttlemeister? Tried a Throttle rocker once, didn't like the "feel" of it being around my throttle hand. I use the TM to give my wrist the occasional rest, especially on slabby rides. Link to comment
John Dickens Posted September 17, 2006 Share Posted September 17, 2006 I've tried the throttle friction screw and a 'flip a lever' cam type locking device but neither really worked under normal road conditions. It's rare that you can use a constant throttle setting for very long, at least in England. I found the throttle rocker to be perfect. It takes the strain off your hand and you can rotate it out of the way for normal driving. Link to comment
tjsven Posted September 17, 2006 Share Posted September 17, 2006 I've used the Throttle Rocker for 54,000 trouble free miles... Never a problem w/ heated grips... At ten bucks a pop there not much downside if you don't like it... Link to comment
freecoder Posted September 17, 2006 Share Posted September 17, 2006 I've used a Flip-a-Lever for several years and many thousands of miles. It has definitely been the best solution for me. - Russ Link to comment
L Rider Posted September 17, 2006 Share Posted September 17, 2006 For me the "Bob's Wrist Rest" has worked well for 3 years. I lubricate the threads once per season.... Cheers....... Link to comment
Schnell Posted September 17, 2006 Share Posted September 17, 2006 I've got 42,000 on mine & I love it. It's never been a problem. I also have a Throttle Meister but use the rocker 10x more. For $10 whats the down side? Try it. Link to comment
Green RT Posted September 17, 2006 Share Posted September 17, 2006 I think you will find that this is one of the topics on which there is widespread disagreement. There are the strong advocates for rockers who think the Throttlemeister/Bob's Wrist Rest are useless. And there are those with exactly the opposite opinion. You just have to try them out for yourself. There is no right answer and there is no consensus here. Link to comment
ednap Posted September 18, 2006 Share Posted September 18, 2006 Go all the way, install an MCCruise http://www.mccruise.com/ Link to comment
RTme2 Posted September 23, 2006 Share Posted September 23, 2006 I use a Throttle Rocker on my 11RT. Works great. Dave Link to comment
