Mr. Bill Posted September 14, 2006 Share Posted September 14, 2006 I have an R1100RT with 68,000 miles and I have noticed that I have a lot of free play in the front disc brakes. The floating disc seems to have too much float to it, about 3/16".The disc does not have too much wear on the pad area so do you think just replacing the 12 roll pins on each disc would do the job? Link to comment
ninermatt Posted September 14, 2006 Share Posted September 14, 2006 Thats what you need to do http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?mospid=48862 Link to comment
Ken H. Posted September 14, 2006 Share Posted September 14, 2006 Are you talking about side-to-side to play, or rotational play? If the former, this is normal. If the latter, you need new rotor buttons. Link to comment
bmwmick Posted September 14, 2006 Share Posted September 14, 2006 I have an R1100RT with 68,000 miles and I have noticed that I have a lot of free play in the front disc brakes. The floating disc seems to have too much float to it, about 3/16".The disc does not have too much wear on the pad area so do you think just replacing the 12 roll pins on each disc would do the job? Bill, Read this: http://www.ibmwr.org/ktech/floating-disk-rollers.shtml plus both Addendums. Your R1100 and the K1100's use the same rotors and bobbins. Mick Link to comment
