lthj75 Posted September 13, 2006 Share Posted September 13, 2006 Everytime I push the lock/button to open the storage compartment (where the radio would be) the button gets stuck in the down position. It seems to get caught on the body fairing. I need to reach down from the front and push the lock area back towards me and it pops back up. This every happen to anyone else?!? Link to comment
1200Bob Posted September 13, 2006 Share Posted September 13, 2006 Had my bike for over a year and never had the problem you described. I would hope this nuisance is covered by the warranty. Link to comment
Gordon K Phillips Posted September 13, 2006 Share Posted September 13, 2006 I have had this problem a couple of times on my 05 R12RT. It happens when you push the button down at an angle. I now know all I have to do is center the button while pushing it down with my finger and the button will pop up the normal way. There is enough play, that if you push down off center, it will catch under the edge of the fairing. It is not a problem and if you use care when you push the button down it does not happen. Link to comment
Geraldh Posted September 13, 2006 Share Posted September 13, 2006 Nope, no problems up here. Link to comment
bross Posted September 13, 2006 Share Posted September 13, 2006 Mine used to catch when opening it. Until I did the 10,000kms service and had all the plastic off. Re-installed the plastic and it works like a charm now. I would just loosen the screws around the compartment and try it a few times to find where it works best, then snug the screws back up. Link to comment
mos Posted September 13, 2006 Share Posted September 13, 2006 I have had that problem when the plastic was removed , by me, and the button was not centered when replacing the plastic . It is not hard to remove the screws to and fix the problem . Link to comment
ScottT Posted September 13, 2006 Share Posted September 13, 2006 Happened to me after I did my first service. I didn't have the panel aligned quite right. I loosened everything and realigned. No problem since. Link to comment
bimmers Posted September 15, 2006 Share Posted September 15, 2006 use a little oil and it also helps but alignment is key. No problem on my part. Link to comment
