mos Posted September 10, 2006 Share Posted September 10, 2006 Does anyone have a list of items done at the 12,000 mile service . I want to do as much as I can to keep the cost of the service down . I have changed the oil and filter , Transmission oil . Mike Link to comment
Karasek Posted September 10, 2006 Share Posted September 10, 2006 Your dealer can provide you with one. Link to comment
St0nkingByte Posted September 10, 2006 Share Posted September 10, 2006 Here is the list for what the maintenance schedule calls the "BMW Inspection (every 20,000 km)" Reading fault-code memories with the BMW Motorrad diagnostic system Performing bleed test with the BMW Motorrad diagnostic system Changing engine oil Changing gearbox oil (regular maintenance)*) every 40,000 km Checking secondary spark plugs Adjusting valve clearance Replacing all spark plugs (during servicing)*) every 40,000 km Replacing intake air filter element Replacing alternator belt (during servicing)*) every 60,000 km Visual inspection of hydraulic clutch system Checking front brake discs for wear Checking front brake pads for wear Checking brake-fluid level, front brakes Checking rear brake disc for wear Checking rear brake pads for wear Checking brake-fluid level, rear brakes Checking freedom of movement of throttle cable and checking for kinks and chafing Checking tyre pressures and tread depth Checking ease of movement of side stand Checking ease of movement of centre stand Checking lights and signalling equipment Function test, engine start suppression Checking synchronisation Test ride as final inspection and function check Reading fault-code memories with the BMW Motorrad diagnostic system Checking battery charge state Confirming BMW Service in on-board documentation Link to comment
St0nkingByte Posted September 10, 2006 Share Posted September 10, 2006 Oops and I forgot I have a copy of the R1200RT maintenance schedule PDF that you may want to download from here: http://st0nkingbyte.whizy.com/files/R1200RT_maint-sched.pdf There's also an annual service with differing steps depending on the year you might want to review that in conjunction with the list above as you'll want to mix and match based on the mileage and the year. Link to comment
