bmwterry Posted September 6, 2006 Share Posted September 6, 2006 OK, I bought the bike (see lower post). Are there any comprehensive tech articles on this or will I have to buy a manual? I've changed clutches on airheads, is this much different? The on line parts fiche tells me there isn't a lot more to it. Link to comment
Dances_With_Wiener_Dogs Posted September 6, 2006 Share Posted September 6, 2006 Are there any comprehensive tech articles on this In a word...yes. First, familiarize yourself with the Search Feature. You might want to spend some time looking at the M/C FAQ though it doesn't specifically mention the clutch replacement. Look at these different threads... this one and this one and this one too. Jamie, aka KMG_365 has written many excellent articles and is quite knowlegable about, well, darned near everything! I did a search with the parameters of 1-year and his user name and "clutch replacement" and found a gem: HERE. You'll want to balance what the manual says with questions to us here. I know that Haynes tells you to completely remove the rear subframe, which is absolutely not necessary. Have fun! Link to comment
bmweerman Posted September 6, 2006 Share Posted September 6, 2006 Are there any comprehensive tech articles on this In a word...yes. First, familiarize yourself with the Search Feature. You might want to spend some time looking at the M/C FAQ though it doesn't specifically mention the clutch replacement. Look at these different threads... this one and this one and this one too. Jamie, aka KMG_365 has written many excellent articles and is quite knowlegable about, well, darned near everything! I did a search with the parameters of 1-year and his user name and "clutch replacement" and found a gem: HERE. You'll want to balance what the manual says with questions to us here. I know that Haynes tells you to completely remove the rear subframe, which is absolutely not necessary. Have fun! What he said + When intalling the friction plate make sure you put it in exactly as shown...not as..ahem..a certain member or this board once did and put it in backwards in which case you get to to do the job twice Stop snerking out there...it's easier than you think to put it on the wrong way. Good luck, it's a big job but you and the bike will feel great when it's done. Cameron Link to comment
bmweerman Posted September 6, 2006 Share Posted September 6, 2006 Just thought I would throw this up here for your perusal. Would have helped me my first time. ------------- Tools Decent set of metric hex bits and sockets 30 mm socket 12 mm` hex tool Clutch alignment tool Clamps for gas lines Heat gun or torch 2 ratcheting straps 17mm long socket if one forgets, as I did, to adjust the clutch before putting bike back together. Touque Wrench(s) ------------------------------------------------------------------------------------------------------------------------------------- Parts Clutch disk -------------------------------------------------------------------------------------------------------------------------- Misc…Stuff 3 7mm 40mm 1.0 pitch bolts for starting transmission reasemble Assorted Washers Long 8mm 1.25 pitch carriage bolts with heads cut off for transmission removal …instilattion. Vice Hack Saw Moly lube Honda Moly 60 Paste Krytox Carb cleaner for cleaning splines Wd 40 for breaking loose exhasust Support for swingarm Cardboard box for final drive -------------------------------------------------------------------------------------------------------------------\ Useful Information http://www.onlineconversion.com/ 1 pound foot = 1.355817952 Newton Meter 1 Kg-m = 9.80665 Newton Meter Clutch plate bolts require 6mm hex tool torque spec 18 Nm = 13.276 ft pounds \ Rear Shock Absorber Bolts 50 Nm = 36.9 ft/pd Frame Bolts 4 Torque = ? Muffler (Silencer) Clamp Bolt 50 Nm =36.9 ft/pd Rear brake caliper mouning bolts 40 Nm = 29.5 ft/pd Link to comment
Dances_With_Wiener_Dogs Posted September 6, 2006 Share Posted September 6, 2006 I was reading the MOA magazine at lunch and Ted has his spline lube DVD listed in the classifieds. It's a whole $12. tedanddenise@comcast.net 717-264-2905. Link to comment
BeemerWrangler Posted November 1, 2006 Share Posted November 1, 2006 I just rebuilt my clutch after 27k (7k by me in the last 6 months). This forum has been a huge help, and though I can't think of everyone who's been of assistance -- thanks to you all for posting your trials, tribulations, and advice! Link to comment
