cabbage Posted September 4, 2006 Share Posted September 4, 2006 I've seen these used to hold the din plugs from Autocom systems. They seem to adhere to bike bodywork or helmet sides and provide a place to clip your plugs when not in use instead of them hanging loose. What are they called and where can I buy them? Cheers Cabbage Link to comment
EffBee Posted September 4, 2006 Share Posted September 4, 2006 Autocom part number FA-02 Link to comment
gfountain Posted September 5, 2006 Share Posted September 5, 2006 Check West Marine boat hardware online. They don't have the adhesive but you can apply some double sided tape. They are used on boats to clip miscellaneous items. I went a different route on my RT. I picked up some large O-rings at the hardware store and pinched them underneath the rails on my gas tank so that only a small loop stuck out. They hold the din plugs nicely and look real clean. I also found some small plastic caps like the larger ones used on chair legs that fit the din connectors perfectly. Makes for a nice finish and keeps dirt and water out of the connectors when not in use. Link to comment
John Bentall Posted September 5, 2006 Share Posted September 5, 2006 They are called P-clips and come in packs of 2 priced at £2. Autocom part #1550, previously known as part #159. They adhere extremely well. Find your nearest dealer from www.autocom.co.uk Link to comment
bakerzdosen Posted September 5, 2006 Share Posted September 5, 2006 Not that it'd be hard to find, but this is what Fernando is talking about. (So you can see the picture.) Link to comment
