Mike T Posted September 4, 2006 Share Posted September 4, 2006 Which hoses do you hook up a fule pressure gage to? The BMW manual call for the "Discharge" hose. The manual shows the "top" hose (where the fuel hoses attach to the plastic pipes on the presuure regulator) being hooked up to the gage. The manual shows the top hose as the input hose from the tank. When I use the top hose to test the pressure it reads Zero. When I use the bottom hose it reads about 50lbs psi. The spec for my bike is 3 bars. Am I doing the reading correctly? Thanks Link to comment
Ken H. Posted September 4, 2006 Share Posted September 4, 2006 50 psi seems a little high, 45 is more the norm, but you are likely fine. Link to comment
