Bud Posted September 3, 2006 Share Posted September 3, 2006 What's the deal with my bike. Turn the grips on to high last night and the throttle won't return. Stays on. Can move it back by hand. NOT GOOD! Help, answers, suggestions, I don't knows, anyone, anyone??? Link to comment
philbytx Posted September 3, 2006 Share Posted September 3, 2006 Not a terminal problem it just needs adjusting! You need to move the multifunction end a tad away from the handlebar end weight. There needs to be a space of about the thickness of a credit card between the end weight and the twist grip/throttle tube assembly to allow for expansion. Link to comment
Z-Man Posted September 3, 2006 Share Posted September 3, 2006 A particular problem if you have a Throttlemeister, but once you adjust it properly you're good for a long spell. Link to comment
CraigT Posted September 3, 2006 Share Posted September 3, 2006 Are yours factory fitted? I had this with my RS, but I'd fitted aftermarket grips myself. They were tight to get on and I had to file down the OEM ridges below the rubber handgrip. Would stick constantly once any level of warmth got into them. Cut them off the following saturday and fitted the handgaurds from the GS. Much more effective. Link to comment
Rinkydink Posted September 4, 2006 Share Posted September 4, 2006 I just wish it was cool enough where I live to need my heated grips. Link to comment
outpost22 Posted September 4, 2006 Share Posted September 4, 2006 Not a terminal problem it just needs adjusting! You need to move the multifunction end a tad away from the handlebar end weight. There needs to be a space of about the thickness of a credit card between the end weight and the twist grip/throttle tube assembly to allow for expansion. Ditto on that. Just had it happen on my new F650GS. Just slide the assembly AWAY from the bar end weight. Link to comment
Paul Mihalka Posted September 5, 2006 Share Posted September 5, 2006 If you have a problem with loosening and moving the whole throttle/switch assembly, you can unbolt the bar end weight and put a washer on the bolt between the weight and the handlebar end to separate it a bit. Link to comment
Bud Posted September 5, 2006 Author Share Posted September 5, 2006 If you have a problem with loosening and moving the whole throttle/switch assembly, you can unbolt the bar end weight and put a washer on the bolt between the weight and the handlebar end to separate it a bit. Thanks for the advice. Link to comment
