Dances_With_Wiener_Dogs Posted September 3, 2006 Share Posted September 3, 2006 Someone mentioned I could turn it off by holding the starter button and turning the key...I think. Was this model designated to have it turned off or am I tricking the system? Link to comment
Paul Mihalka Posted September 3, 2006 Share Posted September 3, 2006 It was designed to be able to turn ABS off, but not while riding. Correct: Hold down ABS button and then turn on ignition - no ABS, warning light stays on. To get ABS back, you stop, turn ignition key off. When you turn on again, you have ABS again. Link to comment
Dances_With_Wiener_Dogs Posted September 3, 2006 Author Share Posted September 3, 2006 It was designed to be able to turn ABS off, but not while riding. Correct: Hold down ABS button and then turn on ignition - no ABS, warning light stays on. To get ABS back, you stop, turn ignition key off. When you turn on again, you have ABS again. Excellent! Thanks Paul! Tomorrow I'm riding a trail where I can see the definite advantage of no ABS. Link to comment
