llotse Posted August 26, 2006 Share Posted August 26, 2006 I have searched the forums but cant seem to find the answer . Can anyone who has fitted accessories to the R1200RT tell me where they took the power from please? Is there a dedicated socket hidden somewhere? I am about to fit an Autocom system. Link to comment
tgrrdr Posted August 26, 2006 Share Posted August 26, 2006 I've seen this answer posted somewhere here before - tap into the rear powersocket wire. I bought my 2005 RT used and that's how the previous owner had wired his autocom. The only downside was that the power socket was disconnected (at least the way he had it wired). Electrical connection and Touratech both have power distribution plates you can use if you'll be adding more than 1 or 2 accessories or want to have a fused power source. I bought one of the exlectrical connection ones but haven't wired it up yet (on my RT) - I've also had one on my Tiger for a year or two and it works great. Link to comment
Marty_H Posted August 26, 2006 Share Posted August 26, 2006 Buy the Touratech Can-Bus relay power distribution panel - here's how I did it: http://homepage.mac.com/hamiltonm/My%20Website/page7/page18/page18.html This device is approved by BMW to work with the Can-Bus network and eliminates the need to tap into the GT1 plug, as so many do with sometimes unpleasant results. Holler at me if it does not make sense. Link to comment
CruisinCruzan Posted August 26, 2006 Share Posted August 26, 2006 If you plan on adding additional accessories just wire in a fuse block and then add away with minimal worry. Link to comment
Ken H. Posted August 28, 2006 Share Posted August 28, 2006 What Marty said. The Touratech TPS-15 will handle four aux. devices, up to 15 amps total, directly. Link to comment
gfountain Posted August 29, 2006 Share Posted August 29, 2006 One more vote for the Tourtech TPS 15 CANbus Helper. So far it powers the Autocom and a readar detector on my bike. One side note. I did not power the relay circuit of the CANbus helper from the accessory socket. It was pointed out in an earlier thread that this would lead to powering the device if you were to use a battery charger that plugs into the accessory socket. I powered the TPS 15 from the circuit that powers the running lights. Link to comment
