red102 Posted August 24, 2006 Share Posted August 24, 2006 I have the infamous "grub screw" on my right side caliper. Just recently purchased speed bleeders. Is there any thing special I need to know about removing the dad blasted grub screw. It may be as easy as unscrewing but I wanted to check before creating a big mess. Thanks in advance for your help. Stan Link to comment
duckbubbles Posted August 24, 2006 Share Posted August 24, 2006 Hi, Stan- I think that you are referring to the special "bleeder" fitting that comes on the bike from the factory. Mine was just tighter that hell when I removed it from my 99 R11S. Replaced it with a standard fitting. Frank Link to comment
John Dickens Posted August 24, 2006 Share Posted August 24, 2006 It does 'just' unscrew but it's in pretty tight. Mine came out without heat by using a wrench on the flats of the fitting and a vice grip on the body of the fitting. Link to comment
bikerfish1100 Posted August 24, 2006 Share Posted August 24, 2006 my grub screw was internally stripped (allen key hole) fromt eh last time a shop worked on it- so i just yanked the entire thing (grub and holder), and installed a Speedbleeder directly into the caliper. problem solved quite neatly. less weight, too. Link to comment
myshkin Posted August 24, 2006 Share Posted August 24, 2006 The recommended procedure is to appl a little heat to loosen the loctite. Mine loosened up without the heat, however, and the speed bleeder fir perfectly . Link to comment
