Lawman Posted August 15, 2006 Share Posted August 15, 2006 I wired my Motolights to my accessory plug under the rear seat..I did not splice into the wire but temporarily stuck the wire into the socket in the plug and taped it in..I need a male plug to to connect to my Motolight power lead..Any suggestions ? Thanks.. Link to comment
DonSydney Posted August 16, 2006 Share Posted August 16, 2006 Do you mean you just need a male plug to plug into the accessory socket ? If so, the plug is a standard item from Hella. Cheers Link to comment
Scarver Posted August 16, 2006 Share Posted August 16, 2006 Assume you don't have the accessory socket installed but are using the plug for it that is part of the wiring harness. You should be able to modify a nylon or vinyl covered push-on connector (available at a local Autozone or O'Reilly's). Here are some sample images of these crimp-on connectors. Link to comment
Lawman Posted August 16, 2006 Author Share Posted August 16, 2006 Thanks for the link.. Insulated bullet terminal is just the ticket.. Link to comment
