texasaggie97 Posted August 15, 2006 Share Posted August 15, 2006 I wanted to see if a few of the readers would share with me the tools I should have in my tool box in order to do a tune up on my bike. I have a 2003 1150 GS. Please shoot me a list of the tools you use all the time. I am not made of money I just live to ride and I wanted to buy the tools I need to do the work myself. This bike is my baby and I want to make sure she is always running in tip top shape. Thanks for all the help. Todd Link to comment
Joe Frickin' Friday Posted August 15, 2006 Share Posted August 15, 2006 I wanted to see if a few of the readers would share with me the tools I should have in my tool box in order to do a tune up on my bike. I have a 2003 1150 GS. Please shoot me a list of the tools you use all the time. I am not made of money I just live to ride and I wanted to buy the tools I need to do the work myself. This bike is my baby and I want to make sure she is always running in tip top shape. Thanks for all the help. Todd Look for a tool list in here, starting on page 2; that ought to cover it. Link to comment
Jake Posted August 15, 2006 Share Posted August 15, 2006 What’s in the bag? By Tom Roe Core Philosophies Use the tools that you carry on your bike, to work on your bike. Using the tools that you carry will help give you confidence. It quickly lets you know what you need to add to the kit. Your bike breaks down and you are stranded, in a strange place with no one for miles, the last thing you need is to do is open the factory kit and start wondering what this tube with the holes in it is for! Start with the stock tool kit and work up. Your kit has a 12mm and a 14mm end wrench but the people you are with need a 13mm. Look to add commonly used items. Carrying tools that you don’t know how to use. Although you may not know how to use a multimeter or a siphon hose, the person who stops to help you, sometimes a motorcyclist in his cage, will know how to use them. Carry tools to help yourself and others. Siphon hoses and jumper cables fall into this category. These items require a friend. Good touring Karma Upgrade the quality of your tools. Take pride in what you carry. They can help you or others out of a tight jam when called upon. The tools that I carry* *Always subject to change First Aid Kit Cold Pack Space Blanket Tow Service Contact Sheet Phone List Cell Phone Credit Card $100 In Small Bills Flashlight Batteries Tire Gauge Duct Tape Siphon Hose Dual Lock Leatherman Multi Driver Shock Spring Tool 3/8 Ratchet Plug Wrench Torx wrenches Allen Wrenches 3mm T Handle Allen Lug Wrench Vice Grips Crescent Wrench Filter Wrench Hemostats Needle Nose Pliers End Wrenches Multi Meter Electrical Wire Wire Strippers Wire Cutters Spare Fuses Electrical Tape Crimp On Connectors Zip Ties Spare Bulbs Tire Irons Tire Repair Kits WD 40 Feeler Gauges Jumper Cable Tow Strap Link to comment
flars Posted August 15, 2006 Share Posted August 15, 2006 The absolute minimum for adjusting the valves: 1. Feeler guages. Two for the intakes and two for the exhaust. 2. A short 10 mm (or is it 12 mm?) open or box for loosening the locking nut. Using a short wrench lessens the chances of overtightening stuff. There is probably one in your bike's tool kit. I am pretty sure your bike's tool kit includes the 3 mm hex needed for the valves and the larger hex for removing the valve covers, and the spark plug wire puller and wrench. If you are going to sync the carbs, you will need a 10 mm open wrench to loosen the throttle cable lock nut on the right TB. You also need a set of needle nose pliers to help hold the cable adjuster still when you retighten the lock nut. And of course, a manometer, mercury sticks, carbstiks or TwinMax to balance the TB. You will need a couple of wrenches if you are going to replace the alternator belt. Could be 15, 17 and 19, but I am not too sure. Link to comment
texasaggie97 Posted August 15, 2006 Author Share Posted August 15, 2006 Great help. I can not believe the help this site is. Thank you for your time and effort. Link to comment
