twilmotte Posted August 15, 2006 Share Posted August 15, 2006 I've read a few posts advising that disabling the IF sensor on the Garmin 2610 will keep the screen display from changing while riding in bright sunlight. When I finally got around to reading my Owner's Manual, however, I couldn't find any reference to disabling the IF sensor. Can anyone clue me in on how to do it? It is very annoying when (for no apparent reason) my screen display sometimes changes while I'm riding. Link to comment
Scarver Posted August 15, 2006 Share Posted August 15, 2006 Tom, To disable the IR remote control: From any page, press the 'Menu' key, then select 'Options'. Select the 'General' tab, then press the 'Menu' key. Select 'Disable Remote'." Link to comment
twilmotte Posted August 15, 2006 Author Share Posted August 15, 2006 Thanks, Herman. That was easy enough. Now I'm anxious to see if disabling the IF sensor will help my screen stay on task. Link to comment
Tommy_Boy Posted August 15, 2006 Share Posted August 15, 2006 I used the somewhat more "primitive" method - a piece of electrical tape over the sensor. And it does help the unit stay on task. Link to comment
RonStewart Posted August 15, 2006 Share Posted August 15, 2006 Gonna be pedantic, twilmotte. IR stands for infrared. Sunlight contains infrared light, and of course, so does the remote control. It's not IF. Hope that's helpful. One way or the other, I sure am AR. Link to comment
SacKen Posted August 16, 2006 Share Posted August 16, 2006 You may have to update the firmware in your unit if you don't see that option. The Garmin updater will check for the latest update for you. Link to comment
