RapidDog Posted August 14, 2006 Share Posted August 14, 2006 I want to remove my handlebar/grip assembly from the cast handlebar. I'm backing out the one bolt at the top/center of the cast bar that appears to be holding the assy on, but it's taking more effort than I expected. Is there some sort of locktite on this bolt or am I totally off track here? I don't want to strip it. Link to comment
Ken H. Posted August 14, 2006 Share Posted August 14, 2006 It is indeed loctite'd in place. Heat is the key. Take a heat gun (not a torch!) to the head of the bolt long enough (2-3 min.) for it to seep in to soften the loctite. Link to comment
Joe Frickin' Friday Posted August 15, 2006 Share Posted August 15, 2006 I want to remove my handlebar/grip assembly from the cast handlebar. I'm backing out the one bolt at the top/center of the cast bar that appears to be holding the assy on, but it's taking more effort than I expected. Is there some sort of locktite on this bolt or am I totally off track here? I don't want to strip it. Did this a couple of years ago on Knappy's bike. After the bolt comes out, the steel handle portion is still a light press-fit inside the aluminum riser. I can't remember exactly how I got it out, but heat was involved (the aluminum expands faster than steel). Two ways I can think of: 1. get a bolt like the one you took out, but a couple inches longer. Install it all the way until it stops turning (don't force it; don't want to mangle threads). Heat aluminum, pound on bolt head with hammer to drive steel part out. 2. clamp steel portion in copper-jawed vise. Not too tight, don't want to crush steel. Heat almuminum, twist/pull aluminum to work it off of the steel. Whatever you do, you're going to want to wear some heavy gloves; the heat will readily travel to all parts of the aluminum piece. For reassembly, you can use the original bolt to pull the steel part into the hole. Consider a touch of lube under the bolt head (but use only Loctite on the threads) to keep from galling the aluminum. Also recommend heating the aluminum prior to reassembly. Link to comment
