BMWSportTouring
KMG_365
Bleedin' 1150's brakes can't stop Mama Hoon!
KMG_365
It's here!! By popular demand! Leslie and Arianrhod show you how easy it is to do your own ABS brake bleed on the '02 BMW R1150RT!
A little background: Leslie bought Marty's 1150RT back in April with 30K on it and named her "Arianrhod" after the Celtic Moon Goddess whose name literally means "Silver Wheel". She has proceeded to become quite the rider and has even recently earned the title "Mama Hoon"! :) Despite still being almost a novice rider (only about two years), she's put well over 16,000 miles on Arianrhod since Easter! The RT just begs to be ridden far, wide, and hard--but putting on those kinds of miles sure can make those expensive services come around quickly! Arianrhod is about two years old now and it's time to bleed the Wheel Circuits and the Control Circuits on the ABS integral linked brakes, as well as the hydraulic clutch.
I had bled the ABS Wheel Circuits last week on my '03 and she observed the procedure closely. She said she wanted to do her own full bi-annual/major service this time. She'd seen it done once before and we have the shop manual from Motobins in the UK to follow along with all the required steps. For the record--I didn't even help (I think I helped break one or two bolts loose)--my hands stayed clean enough to take these pictures. Keep in mind, Leslie went to school in the days when "girls" didn't take auto shop--her only option at that time was Home Economics. She also didn't grow up around a mechanic's shop or hand tools, and is totally taking to this new-found hobby with some trepidation, but a determination that is MOST impressive!
So all you guys and gals out there who have been intimidated by the thought of doing your own services, or consider yourselves not to be mechanically inclined: sign up for the next Tech Daze near you! If there isn't one--start your own! If you schedule it, they will come! But if you've got an 1150 and would like to see what's involved in servicing those mysterious linked, power-assisted brakes (you know, the ones where, if you dare to touch them yourself will set a pox upon your house for generations to come--as well as void your warranty! :grin: ), set a spell, pour yourself a cold one, and let Les walk you through the fairly simple steps to saving yourself thousands of dollars and keeping your R1150RT running in tip-top shape! :Cool:
This will hopefully be the first in a series of photo-documented service walk-throughs. She also just did her tranny fluids, final drive fluids, and fuel filter change. We forgot to photograph the rest of the annual and major service: oil and oil filter change, valve adjust, TB synch, throttle cable and fast idle cable freeplay adjustment, etc. Maybe next month when we get back from the UnRally! :)
I had made one of rosemab's funnel-thingy's (which he once christened the "Mini-Stan" :) ) from info on this DB. It works like a champ and MAJOR kudos to everyone who contributed to this fascinating discussion! I had ordered a few SpeedBleeders for my bike, but the sizing info on their page is incorrect for the '02's on. Still, I would HIGHLY recommend them! They take an extra step to install the first time, but then--oh, the simplicity of it all! The "Mini-Stan", a syringe with some tubing (and an old stock bleed screw stuck in the end!), the SB's, in addition to the TOTALLY slick catch bag with silicone hose SpeedBleeder sells, makes it an amazingly easy procedure! You should definitely have the BMW shop manual handy and read through all the procedures and cautions before you start! Motobins in the UK sells it on CD for a great price (and they have a great catalogue, too! :) ). I printed out the pages and put them in plastic sheet protectors (back to back! :) ) and placed them all in a three-ring binder. If you're uncomfortable with any of the steps, get help before you screw something up irrepairably! We offer this tutorial merely as a service to the members--don't send your lawyers to come banging on my door cause you got yourself in over your head. :D RTFM! :rofl:
Here are the main specialized tools of the trade you'll need to make the job easier:
The Mini-Stan, a 60cc syringe with 8" or so of 1/4" I.D. X 3/8" O.D. vinyl tubing and the stock 8mmX 1.25 bleed screw stuck in the end to keep it from dripping, and the catchment bag SpeedBleeder sells to keep everything neat and clean.
And here is a fuzzy detail shot of the special order ABS "Bleed Plug" Part# 90886342541, Desc: "TOP". You can order one from Marin BMW perhaps you've heard the name S. Cary Littell, Jr.? If you're reading this you owe him more than you'll ever know. I bought a rubber washer (that I had to cut the middle out of to make fit) to seal it well, since it will be holding brake fluid above the level of the reservoir.
I came home from work one morning to find Arianrhod sitting stark naked in the garage! Leslie had already pulled all the Tupperware, glove box, air intakes and even the tank!
The BMW R1150RT uses a new concept in ABS brake technology that is very different from standard brakes, which you may or may not already be familiar with. Without getting into the fact that BMW has not felt the need to allow us the ability to unlink the two brakes--instead of a Master Cylinder mounted on/near the hand and foot controls that actuates the brake caliper(s) directly, the 1150 uses two separate circuits: a control circuit actuated by the hand and foot controls which controls the servo-assisted wheel circuit (under the gas tank) which then powers the calipers at the wheels. This means that the normal reservoirs you might be used to seeing, and the caliper(s) at the wheels are not really directly connected at all! :eek: The wheel circuits are bled every year (they are under the most pressure) and the control circuits are only bled every two years.
The reservoirs for the wheel circuits are on the left (port) side of the main ABS housing under the tank. The front wheel circuit reservoir is fore, and the rear wheel circuit is aft. The bleed screws for these reservoirs are on the calipers at the wheels themselves. On the right (starboard) side of the main ABS housing are the six bleed screws for the control circuits front and rear. The reservoirs for these control circuit bleed screws are at the right hand grip (in front of the hand brake lever) and at the right side rear (under the black plastic panel).
Here are two shots trying to show the six control circuit bleed screws (with the dust caps removed for clarity) on the starboard side of the main ABS housing under the tank:
See the fuel filter replacement walk-through (coming soon! :D ) for details on how to remove the tank.
Remember, that since the brakes are permanently linked, all the calipers must be either properly installed (with pads!), or removed and securely shimmed! If you switch the bike on and touch either control, the pistons will otherwise be slammed together! Open the front wheel circuit reservoir with a 19mm wrench and draw off the old brake fluid. (The rear reservoir is shown here, but the front reservoir is immediately to the fore)
Remove the front brake calipers, push the pistons ALL the way out, and shim them securely in
place.
If your front pads are worn, your shims will hit the raised nubs at the ends and bottom of the calipers and they will not be able to keep the pistons fully retracted. If this is the case, place additional shims on the outside of each pair of shims, between the shims and the pads on each side to keep the pistons fully retracted when actuating the servo. Two shots for clarification:
After pushing the pistons all the way out, the brake fluid in the lines will be forced back into the reservoir. This is why you draw off the fluid first--to prevent an overflow. Now draw off this additional fluid in the same way as before, then attach the Mini-Stan and fill the reservoir with fresh DOT4 fluid FROM A CLOSED CONTAINER. When you break the seal on a bottle of brake fluid, the clock starts ticking. You should replace the fluid every year (regardless of miles), so why not start with good, uncontaminated stuff? Here's a picture of the Mini-Stan installed in the front reservoir and filled with fresh DOT4.
Instead of needing a power assisted brake bleeding device like the Mighty-Vac, BMW has thoughtfully provided you with a built-in, servo-assisted, bike powered brake fluid pump! Be vary careful when squeezing the controls! If you pump away like normal brakes, you will empty the reservoir in no time, cavitate the pump, and contaminate the system with air! Remember, air does not compress the way brake fluid does--you need that compressive strength to stop you--air in your brake system is NOT your friend! :(
Switch on the bike and wait for the ABS to perform its initialization and self-check. Crack the bleed screw 1/4 to 1/2 turn and bleed the left side slowly until the fluid coming out is nice and clean, clear in color, free of bubbles, and always keep the Mini-Stan at least partially full of fluid--then do the right side the same way. Remember, if you're doing the bleed with the stock bleed screws, and especially if you're not using the silicone hose, you must close the bleed screw before releasing the lever to prevent air from being drawn back into the brake line (which the SpeedBleeders' ball check valve automatically prevents!). Air can be sucked back in around the threads as well when fluid is not being forced out through the bleed screw, when you release the hand control. When you're done with the right side, bleed enough fluid down just until the fluid disappears from the stem of the funnel-thingy. Remove the funnel, and assure that the fluid level is just below the "MAX" mark. It will drop a bit when the caliper pistons return to their previous position.
Remember, if you are installing SpeedBleeders: since the system is not closed, and the calipers are below the level of the reservoir, when you remove the stock bleed screw, the brake fluid will leak out. Just wrap paper towels around the calipers, quickly swap the stock screw for the SB--being careful to not cross-thread it in the process--and carefully wipe off the spilled brake fluid. The first few threads on the SpeedBleeders do not have any thread sealant on them for this reason. Tighten the SB down carefully, feeling for the difference between thread sealant compound resistance and over-torqueing/stripped resistance. The bleed screws only call for 7Nm of torque to fully seat.
After the front calipers are bled, remove the shims and re-install the calipers. Switch the bike on again, wait for the ABS to cycle and then bed in the pads against the rotors. Depending on the wear on the pads, if the fluid drops significantly in the reservoir, top it off to the "MAX" mark again, then close the reservoir cap. Once the front calipers are completely finished, the back is done the same way.
Stay tuned for scenes from our next show: Bleeding the ABS Control Circuit on the R1150RT! :Cool:
Share this post
Link to post
Share on other sites
Limecreek
This is excellent Jamie! I am looking forward to part 2 and it's just in time to use for our Austin Tech Days, with your permission of course. grin.gif
Share this post
Link to post
Marty Hill
Great job Les. Mucho thanks but I'm still coming your way to get the job done under proper supervision. Printed out the page. Did I see dirt under the fuel tank. It was clean at 27k. grin.gif
Share this post
Link to post
StretchMark
Well done! Perfect timing!
We will be duplicating this on my at Chis K's Nov 1 tech day in Conyers, GA.
Share this post
Link to post
MikeC
Limecreek, what's this about an Austin Tec-day? Tell me more please.
Share this post
Link to post
mikewarax
Share this post
Link to post
Sean
Way to go you Leslie, that's excellent! Great write-up Jamie! Very detailed in your documentation of this event.
Share this post
Link to post
Kenny2
Great, no EXCELLENT walk through. Thanks, Leslie .....and Jamie for the pictures.
Okay, there is another thread to nominate members for their service "Above and Beyond" to the members of this board. Gee this is the second, no third...wait, mmmmm...fifth reason to nominate Leslie and Jamie.
(not trying to hijack).
Share this post
Link to post
Haynes
Thanks for taking the time to post all of this.
My last brake fluid change cost me (AUS)$160.
I'll spend a few hours getting this stuff together and do it all myself next time.
If I have any trouble, can you two come over and help?
Share this post
Link to post
rozemab
Nice work!
Share this post
Link to post
Les is more
Share this post
Link to post
Bill Dennes
A really fine job of describing that voodoo job! No small effort on your parts to do it that well, I imagine. Thank you! smile.gif
In the step "draining the rear wheel reservoir," did you take the cap off and dunk the hose end of the syringe into the reservoir?
Share this post
Link to post
JerryMather
Do you have to do anything differently for the 1100 RT?
Share this post
Link to post
RightSpin
Excellent job guys! Looks like another "BMW dealer/technician only" myth disappears into thin air. wink.gif
Hmmmm, what's next? Maybe the clutch replacement is within our grasp afterall. cool.gif
Share this post
Link to post
russell_bynum
You two ROCK!!!
Here we have probably the last big mysterious service that the dealers assure you that you need a Ph.D in mechanical engineering, $200,000 in special tools, and a Shaolin Master to do and it turns out that it is a straightforward and simple process requiring only basic tools. (Shaolin Master optional for entertainment purposes only.)
Awesome.
Share this post
Link to post
Win3855
it turns out that it is a straightforward and simple process requiring only basic tools. Awesome.
The only tool more basic than broken chunks of wood,might be a rock. smirk.gifsmile.gif Great photos and write up. grin.gif
Share this post
Link to post
KMG_365
Hi Greg!
Glad you like it! Of course you all are free to use the info however you wish! I know I'm by far not the first to have done this and have learned much myself from others who have gone before me. If they hadn't posted their experiences and lessons learned, I probably would've continued to try to "pay no attention to the man behind the curtain . . . . " laugh.gif I would love to see any corrections/cautions/additions/tips/tricks to add to this tome for the benefit of us all! For instance:
I forgot to list the proper SpeedBleeder sizes for the 1150.
Front calipers: 2qty 8mmX1.25
Rear caliper: 1qty 6mmX1.0
control circuits: 4qty 7mmX1.0 (I would use longer ones to make them easier to reach!), and 2qty 7mmX1.0-Extra Long (the long stock ones are almost 5cm long overall--SB doesn't make them--yet!)
Clutch bleeder: 1qty 10mmX1.0
Also, unfortunately, though SB makes some metric sizes, they still use SAE stock to make them, so you need a 1/4" open end wrench for the 6mm rear.
Also, some metric wrench sets sold in the US don't have 7mm wrenches for the stock control circuit bleed screws.
Bill,
Yes, you remove the cap to the reservoir and place the hose (with the old bleed screw on the end as a flow restrictor/drip eliminator) down inside the hole and draw off the old fluid--THEN--push out/shim the pistons and re-draw off as much old fluid as you can get out. Remember the photos are just for reference and are not shown in order. Follow the correct order/procedure shown in the manual. I didn't take pics of each individual step to save time, as they would not look that different anyway.
Here is a detail of the syringe/tubing I made for the job:
And a detail shot of the ABS unit showing the front and rear wheel circuit reservoirs:
A better detail shot of the Mini-Stan:
And detail of it istalled:
And Jerry, if you've got the 1100's manual . . . BRING IT!! (yours are even simpler! laugh.gif ) The 1100 uses different size SpeedBleeders, though.
And lastly, if you want to see the photos from the rest of the control circuit and clutch bleeds before I finish the procedure write-up, go here.
Share this post
Link to post
mm02czu
Guy's what can I say, a great article and super photos. Why cant "professional" manuals do it like this. This a real service to the BMW community, many many thanks for taking the time to put this together.
I take it from one post I have missed some of your other posts, its time to dig out your others. This is what the web is all about for me.
Thanks so much, all the best from bonnie Scotland.
Share this post
Link to post
Burt
Jamie & Les,
Great job. I was wondering if it makes a difference if you take the calipers off and shim them, or leave them on the rotor. I just got the funnel and cap to make the mini-stan, and the speed bleeders came the other day. I hope to do mine soon.
Thanks,
Share this post
Link to post
JerryMather
" Why cant "professional" manuals do it like this. This a real service to the BMW community, many many thanks for taking the time to put this together................................" This is what the web is all about for me."
That says it all right there. This site has helped so many people over the years.
I'm pretty impressed with the two of you guys .
Now all I need to do is get the correct speed bleeders and you're going to see me on your doorstep.
Any idea what sizes I need? And will a Haynes manual do or do I need to borrow the CD from someone? frown.gif
Share this post
Link to post
JerryMather
Where can I pick up the speed bleeders after I figure out the sizes that I'll need?
Thanks
Share this post
Link to post
KMG_365
[ . . . ] I was wondering if it makes a difference if you take the calipers off and shim them, or leave them on the rotor. [ . . . ]
BEJ,
I looked into a way to leave them in place--it would be a LOT easier! But I couldn't find a good/safe way to push the pistons out easily while still installed on the rotors. Some folks have mentioned before that they don't bother to push the pistons out at all and just run extra fluid through during the bleed to try to dilute the old fluid trapped in the pistons (you're not going to use that leftover fluid anyway, so why not run it through! wink.gif ). I'm not sure what the inside of the piston/caliper/brake line anatomy looks like and I'd rather get as much of the old stuff out as I can. I had almost 34K on my brake pads when I did my wheel circuits (about 50% worn) so I actually moved my pistons out a good distance and drew off another 50cc or so of old, nasty fluid after pushing them out, so . . . .
You need to be really careful you don't scratch/gouge the rotor. They are very expensive to replace, very difficult to have M/C rotors turned (but possible I hear), a gouged rotor will eat up pads quickly, and it would seem to me that stopping could likely be adversely affected. I don't think scratching the pads would be as serious, as they are a wear item.
I would love to hear anyone's brilliant methods/tricks for pushing the pistons out without prior removal. Especially with the caliper mounted Motolights, the removal was by far the most time consuming step. To add even more time, the Motolights come with a standard metric hex and the 1150 uses Torx bolts now on the calipers, so I've got one of each bolt on each side! frown.gif Sounds like another project!
Jerry,
I've also heard that Pep Boys, and NAPA carry some sizes of SpeedBleeders, but I'm not positive on the 1100's sizes. I think the 1100's use 10mmX1.0's in the front, and you wouldn't have any control circuit screws to replace, but maybe someone who has already replaced the 1100's can confirm that here. Re: Haynes vs. Shop manual: I would feel safer having the BMW manual just to confirm everything (torque settings, etc.), but I'm anal, the Haynes doesn't cover my model year, and the Evo-brakes are a whole new animal. If you've got an older 1100 that the Haynes was written for, you might be okay. But that decision depends on your comfort level, they are brakes, after all. Brake bleed Tech Daze here? Say when! laugh.gif
Also an update: Leslie went for a ride yesterday and she really noticed a significant improvement in the responsiveness of the brakes! She said she even almost dropped it once in a tight turn when she used the old, previously automatic amount of pressure on the handbrake. Good idea to practice a few panic stops and tight maneuvers after a brake service till your cerebellum gets re-programmed! laugh.gif
Maybe when John Moylan gets home from his Tech Daze field trip to GA, he can set something up in the UK for all you chaps across the pond! laugh.gif Otherwise, I may just have to plan on another European vacation! laugh.gif (Hmmmmm, the European Tech Daze Tour, 2004! Got a nice ring to it, don't you think? smile.gif ) I've still got to set something up for my mates Down Under as well! cool.gif Maybe I need to get a side job as a consultant like David, so I can ride and fly all over the world and write it all off on my taxes! LOL!! laugh.gif
Share this post
Link to post
JerryMather
Mike-
Share this post
Link to post
steveP
Thanks Jamie & Les, this may just get me to try it. Always wondered what one did with old brake fluid. How do you guys dispose of it?
Share this post
Link to post
Kenny2
...Maybe I need to get a side job as a consultant....so I can ride and fly all over the world and write it all off on my taxes! LOL!! laugh.gif
Let me know when the Tech Daze is for doing Jerry's 1100. I would like to watch.
Share this post
Link to post
russell_bynum
Jamie was talking about R1100RT brake bleed and said: you wouldn't have any control circuit screws to replace
There are (I think) 2 bleeders on the ABS module under the tank. I've never bothered to replace them with speed bleeders because I figured I'd get all of the fluid out with the bleeders at the wheels, but I suppose there could be some pockets of air or something hiding in there. The best thing would probably be to replace them with speed bleeders as well just to be sure.
I ordered my speed bleeders from www.speedbleeder.com
Share this post
Link to post
RightSpin
Steve, as the consumate environmentalist that I am grin.gif, I transferred the old fluid from the catch bag back into the now empty bottle and tossed it into the garbage. I'm sure most auto parts stores would know how to "properly" dispose of it.
Share this post
Link to post
mikewarax
I usually just dump my used brake fluid in my waste oil container,which goes to be recycled.
Mike
Share this post
Link to post
KMG_365
Aaaaaaaaahhhhhhh!!!!!!!!!!!!!!!! Forgetting for the moment that I have an obligation to report illegal hazardous waste dumping, I feel compelled to remind you that if you are caught illegally dumping HazMat, the fines can range upwards of $1000.00 (in California, at least).
Every city is obligated to provide you a way to safely dispose of your Household Hazardous Waste. I would contact your local municipality or county waste authority and find out where you can take it. The Fire Station is also a good place to start if you can't get the answers from the desk jockys on the other end of the phone.
My current bugaboo is M/C tire disposal. There are places to take car tires to be recycled, but they don't take M/C tires. You can throw them in the regular garbage if you first cut them into 12" sections (they float to the top in landfills!), but the steel beads are a pain to cut through and cutting through that much rubber is a smelly, stinky mess. A local M/C shop may start taking tires from non-tire customers for a nominal charge, but so far I'm letting them pile up for a while! smile.gif
Share this post
Link to post
mm02czu
Hozabout a video of the tech daze, only the actual service steps to cut down the overall time, or cut into sections such as, valve adjustment, TBS, fuel filter change, etc.
Post it as various MEGs or all on a DVD available to members to encourage registration.
Has someone already suggeted this I don't know, but just think sitting some time before, having a run through some time before doing the biz, a shot of suggested tools, required spare parts, no more getting some way through and finding you don't the thingamy bob you require to complete the task.
It would be a lot of work I know but you end up with a permanent record of the work.
Bob
Share this post
Link to post
KDeline
Do any of you gearheads know if this is the same procedure that is used on the K1200RS?
Share this post
Link to post
JerryMather
" Hozabout a video of the tech daze "
Great idea! I know that Bid D was doing a video last year at one o these but, I don't know whatever happened to it.
This may be just the sort of thing that could make Jamie more a celeberity than he already is! wink.gif
So what do ya think big guy you up to being a star?
If you don't host it, maybe we can get Mary Carey after the election to do the honors. grin.gif
In any case I'll donate my bike for the procedure.
Share this post
Link to post
StretchMark
Jamie,
I had ordered from SpeedBleeder before you posted the sizes. They said the rear and the clutch were both 6mm for the 2002. I saw you got the 10mm for the clutch.
I called back again just to confirm the size for the clutch and they said 6mm again. Have you installed the clutch bleeder yet?
Thanks,
Mark
Share this post
Link to post
KMG_365
Mark,
The clutch of Leslie's 2002 1150RT IS 10mmX1.0 !! We just swapped it out with one of the extra 10mmX1.0's they sent me for my '03 (cause the 1150's don't use them in the front anymore!!). I don't know what's going on with Speedbleeder re: the 1150's. I've sent them emails with the correct sizes and even talked to them a few times on the phone recently. I can't believe they are still giving you false info.
Share this post
Link to post
Micks_RS
It was relief to finally find something about bleeding these power assist integral systems. I have an '04 RS but I'd bet the two systems are the same. Did you ever post the the control circuit bleed?
With your experience I hope you can answer a question. I'm putting a set of barbaks on and this may require changeing or rerouting the hose to the resevoir. What I'm trying to find out is what am I going to have to do to bleed for this situation? Hopefully, I won't disturb the system enough to introduce to much air (I know. Even a bubble is to much), but some bleeding probably need to be done. I haven't got the CD from Motobin but will have it when I do the job.
I'd appreciate any help you can supply. I'm new to BMW and realy want to understand what I've gotten myself into. Rideing is fun. I don't want maintanece to be a nightmare.
Mick
Share this post
Link to post
Bill Dennes
Mick - You should be able to install one set of bar-backs on your RT without any cable or hose changes being needed.
Share this post
Link to post
KMG_365
Mick,
I wouldn't think the RS would be that different from the RT as far as cable spacing/slack. "kowboy" had TWO sets of barback on his RT without having to move anything. At the most, you might have to move/re-do some cable brackets/zip ties. I'm going in to work tomorrow for a 72 hour shift (gotta pay for Torrey somehow! wink.gif ), and I'll try to post the control circuits and clutch bleed walk-through this weekend.
Share this post
Link to post
Uli
Great post and good pictures!
I've bled the braken on my 1150 before and encountered no problems at all. My biggest concern was (and is) that a little bit of air might get into the circuit. Since the brakes are power assisted you wont't realize it; the pump will build up the pressure regardless of a little bit air in the lines or so. But when the pump failes you loose that and might have big a problem coming to a stop. To make sure that there is no air in the fluid I rode the bike at 60MPH on a staight road, shut off the ignition (the kill switch will not do) and tried the brakes. I was able to lock them at a speed of about 40MPH;so they worked fine.
If you have a dealer nearby let him check it with the MoDiTec. It's worth the little money.
Share this post
Link to post
StretchMark
Thanks Jamie,
Called Mike at SpeedBleeder and he corrected his documentation and will be sending me the 10MMx1.0 for the clutch. He also said he would get the ordering info on the web page corrected.
Mike also asked if I had any information on a bleeder valve that BMW includes stock on the bike. I'm not sure what he is referring to, but I told him I would send him an email if I found out anything.
Share this post
Link to post
Micks_RS
I hate to beat a dead horse but I'm back. I put the barbacks on '04 RS and, much to my disappointment, I need to change the the brake line from the handlebars. The 1150R hose is the logical replacement. But I still haven't gotten a clear response from all my research on exactly how much of this system I need to bleed.
I saved your Wheel Circuit bleeding proceedure for changeing the fluid next year. I didn't catch the Conrol circuit method. Did it get posted? Do I realy have to go through all that process just for replaceing this line? Can these thngs really be more work for replaceing a line than a car? As I said in my first post, I'm new to the BMW clan and want to learn all I can about these machines. I just don't want to spend time on extra procedures than are necessary for a given situation. I'd REALLY appreciate some direction. Rideing days are rapidly drawing to a halt in western NY. It would nice to get one or two more spins around the block before I have to stick this blue beauty in the back of the garage for probably 7 months. We tend to go from summer to winter to summer with only brief stops for fall and spring.
Mick
'04 R1150RS Pacific Bue
Share this post
Link to post
John Moylan
Haynes the dealer here just quoted a potential buyer of my bike Euro500 for this job......
Share this post
Link to post
John Moylan
Jamie,
This is truly excellent. Good reading in advance of the GA Tech Daze, that's for sure.
Can I ask a question?
  • You mention " push the pistons ALL the way out and using shims to do so, whilstl using 'retract' somewhere else. I presume you just mean pushing the pistons as far back into the calipers as possible. Did you have the cap on the reservoir opened before you did this?
Once again, brilliant post.
Edited by John Moylan
Share this post
Link to post
Zip
Jamie,
Excellent article, thanks. I was able to cut and paste it, color pics and all, straight into a Word document for future reference.
I've been comparing your methods with the BMW CD-ROM. The main difference seems to be that BMW recommends removing the brake pads, instead of removing the calipers, and using spreader tools and adaptors to compress the pistons.
Here are some BMW part numbers, from their CD:
34 1 531 brake resetting tool
34 1 532 locator tool
34 1 533 adaptor
34 1 581 container (for adding brake fluid)
34 1 536 adaptor for rear brake
34 2 532 ring spanner for bleeder nipples (I guess)
Anyway, your descriptions and color pictures are invaluable in taking some of the mystery out this maintenance operation.
I'll probably let the dealer handle this type of work during the warranty period, and pay the big bucks for it. But it won't be long until I switch to doing it myself. As you can see, I am gathering all the information I can to do that, and you have helped in that.
Thanks again,
Share this post
Link to post
KMG_365
Hey guys,
Sorry this took so long to get up. The Control Circuit bleed post is finished. See the Part II thread.
Mick,
Sorry I didn't get back to you sooner. If you replace that front brake line, I would think you'll need to do a thorough bleed of the front control circuit. You'll be introducing a LOT of air into the control circuit system. You'll probably need a few cans of brake fluid and be sure to get all the air out of the system. I don't think, with the way the control system circuitry is set-up, that you could effectively do the reverse-bleed-with-a-turkey-baster approach that you could do with a directly connected master cylinder. Good luck and let us know how it comes out. It seems to me like the bar backs mod could wait till your riding season was already over, no?
John,
Yes. When I said push the pistons back, you are actually retracting them back into the caliper housing. Also, please be sure to read all of the instructions/steps carefully before proceeding: you first open the reservoir cap and drain off the fluid in the reservoir, then push the pistons back fully (i.e. fully retracted), then draw off the rest of the fluid from the reservoir which is pushed back into it from the pistons. If your pads were worn (and especially if the dealer added any fluid at a previous inspection/bleed), there is the possibility of overflowing the reservoir otherwise and creating a real mess. confused.gif
Zip,
Glad to help--and nice job on the archiving! Regarding the BMW shop tools--just try to price those items! shocked.gif Just be sure you're sitting down! laugh.gif I would love it if someone came up with Nifty Beemer Trick #687 for fully retracting the pistons "in situ". It would save fully 50% of the work! cool.gif Perhaps on "Maynard's" control circuit bleed next Fall, I'll look into a way to just take the pads out and shim the pistons out. Perhaps with the pads removed first, a narrower shim could be snuck in between the rotor and the pistons. Hmmmmmmm . . . . laugh.gif
Share this post
Link to post
ygoslow
Thank you for providing the information on changing the brake fluid. I followed your directions and everything came out great. I surprised the heck out of a BMW dealer in Maryland. I scheduled to have my bike checked by their MoDiTeC to check for faults just to be sure I did everything okay. When I told the dealer why I wanted the bike checked and what I had done you should have seen the look on his face. I was a little nervous while I waited I keep second guessing myself. Anyway it only took them about a 1/2 an hour and it was done. I passed the mechanic on the way back to my bike and asked him how I did, he said I shocked the heck out of him. No fault codes I was so proud. Thanks again you did a great job.
Share this post
Link to post
ncsonderman
When are the tech days in GA? I'm new to the BMW community and love to work on my own bikes. How many days is the training? Cost? etc.
Thanks
Share this post
Link to post
ncsonderman
clap.gifThanks for the confidence boost! I just bought my bike and it's due for the 12K. I'll probably have that done by the dealer as it is already overdue, but in the future will try to be my own wrench. I've done brakes on sportbikes in the past with nary a problem, but ABS confused.gif It looks pretty much the same.
Any info. on tech days?
Thanks again for your time.
Share this post
Link to post
Marty Hill
Share this post
Link to post
ncsonderman
Will do, thanks again!
Share this post
Link to post
