final drive seal?
KER
ok, im in the middle of replacing a clutch on an 1100RT-P and have just pulled the final drive. After i released the boot on the final drive and had quite a bit of oil start leaking out of it. The last one i did had just a little bit of oil and this one has me concerned that the seal has gone out. Anyone has some thoughts?
Well, you obviously have a seal leaking at either the final drive or at the rear seal of the gearbox and it's travelling down the driveshaft and collecting at the rear drive. I suppose you know which one it is by now ( since your post ). Replace the final drive seal and you might as well punch a new seal in the gearbox while your there, if you're not sure which one it is. Good Luck!
