ChrisRappl Posted July 28, 2006 Share Posted July 28, 2006 I have installed Hyperlites on my last three BMWs. I would like to install them on my R1200RT, but, I'm not sure if they are compatible with the ABS. It is my understanding that the ABS computer controls the brake lights. I know that they are single filament lamps that act as tail lights with about 2.5 volts applied and brake lights with 12 volts applied. Anybody have any experience with this? Has anyone experienced any problems with them installed? Thanks. Link to comment
Catbird Posted July 28, 2006 Share Posted July 28, 2006 I installed Hyperlites on my '05 RT last summer. The process was straightforward, quick and easy. In order to make sure I purchased the correct unit, I called the company and placed my order directly with them. There were no "issues" with the installation, just follow the supplied directions. Link to comment
weshsu Posted July 29, 2006 Share Posted July 29, 2006 I installed Hyperlites on my '05 RT last summer. The process was straightforward, quick and easy. Ditto here. I installed a set of the R1200RT II Dual Function on my '06 R12RT. They work like a champ. Wes Link to comment
Redbrick Posted July 29, 2006 Share Posted July 29, 2006 Bought my '05 1200RT used and it had Hyperlites already installed...No problems...These have 16 led's in each light rather than the 8 in previous one's I've had.... Phil........Redbrick Link to comment
Jon_M Posted July 29, 2006 Share Posted July 29, 2006 These have 16 led's in each light rather than the 8 in previous one's I've had....Same here. Mine work just fine and are really bright. I installed them so that they modulate continuously, and I plan to modify that so that they pulse for a few seconds, then go steady. I think they are less likely to irritate following cars that way. Link to comment
keithb Posted July 31, 2006 Share Posted July 31, 2006 Hi Chris I was just passing thru Raleigh 4 weeks on the way to Morehead for vacation. I also lived in Raleigh for 7 years. When I buy a new bike the first thing I do is add Hyper Lites and Speedbleeders. I love H.L. and people definitely see them. They absolutely sell them for the new RT's and they are very easy to install. Takes about 20-30 minutes. Since you have installed them before should take you about 15 minutes. I mounted mine to the underside of each grab bar just above the turn signal lens. The LED's are higher and cars approaching from behind see them better. They do not affect the ABS or Can Bus electrical system. Wire them up and enjoy!! Link to comment
ChrisRappl Posted July 31, 2006 Author Share Posted July 31, 2006 Thanks for the replies. I guess I'll get a set ordered. Link to comment
Burt Posted July 31, 2006 Share Posted July 31, 2006 Thanks for the replies. I guess I'll get a set ordered. They have several sets for the 1200RT on their site. I got the one with 16 LEDs per side, and are dual function (tail light and brake light). The installation was very simple, and they are really bright. Link to comment
ChrisRappl Posted August 5, 2006 Author Share Posted August 5, 2006 Well I installed the Hyper-lites this morning. I too opted for the 16 LED Dual Function lights. The model # is R1200RT II. The cost including shipping came to $99.45. They seem to be high quality units and if they save my rear once it will be money well spent. I have come to the conclusion that as far as me and my bikes are concerned there is no such thing as a 10 minute job. By the time I finished it had turned into a two hour project just because I get too anal about everything from routing the wires to soldering to heat shrink and of course cleaning everything that I touch and even some things that I don't. They look good and now I have the added feature of being able to see when the battery charger is charging and when the computer has opened the circuit to the aux sockets. My bike does not have the glowing red hazard cancel button, so, it actually is (kind of) useful. I'll go for a ride tonight to see how bright those 16 LEDs really are. I did clip and insulate (heat shrink that I pinched closed and burnt my fingers a little bit) the green wire so that they flash for 5 sec. and then go steady. I can always release and reapply the brakes if I need to start the flashing again while waiting at a stop. Thanks again for the help and advice of this group. Link to comment
EDO Posted August 5, 2006 Share Posted August 5, 2006 How about a photo of the 16 LED on the RT? Thanks - Link to comment
ChrisRappl Posted August 5, 2006 Author Share Posted August 5, 2006 Attached is a photo. I had some trouble getting the resolution down to 75 KB. Link to comment
Redbrick Posted August 5, 2006 Share Posted August 5, 2006 Hyper-Lites on my 1200 RT with 16 LED bulbs...... Phil...........Redbrick Link to comment
EDO Posted August 5, 2006 Share Posted August 5, 2006 awesome - they look great, I'm sold. Link to comment
Catbird Posted August 5, 2006 Share Posted August 5, 2006 I mounted my 16-LED HyperLites on top of the tail light housing - beneath the luggage rack. So far, I have NOT snipped the green wire. Link to comment
mrzoom Posted August 5, 2006 Share Posted August 5, 2006 I also put a set on yesterday. Nice and easy. I mounted mine as recomended on the side reflectors by the plate. Yes they are bright. Got them from Cycle gagets $75.95 + ship. Link to comment
Jon_M Posted August 6, 2006 Share Posted August 6, 2006 So far, I have NOT snipped the green wire.I just did snip it, five minutes ago. I found myself releasing the brake to avoid irritating or confusing people behind me at stop lights and intersections. I like it better the way I have it now. Link to comment
fla_rider Posted August 6, 2006 Share Posted August 6, 2006 The dual function hyper lights are very apealing but what's up with our Canbus system dealing with this intrusion into it's "domain"? Link to comment
Jon_M Posted August 6, 2006 Share Posted August 6, 2006 The dual function hyper lights are very apealing but what's up with our Canbus system dealing with this intrusion into it's "domain"? The only Canbus complication I found is that, with the "official" BMW battery charger, the running lights portion of the dual-function kit comes on whenever the battery is taking a charge. In effect, the LEDs act like an "in service" indicator light for the battery charger. When the charger comes on, it detects the running lights as a demand and supplies power to them. (I think I've got this right.) It's a little disconcerting to walk into the garage and see the tail lights on when the key is in your pocket. When I asked the Hyperlites rep about this, he said that the current draw in this situation is insignificant and that it is safe to ignore this anomaly. The LED drain is not sufficient to interfere with the normal charging, and when the battery is topped up, the lights will go out. That is in fact what happens. Alternatively, you can just put a quick-disconnect in the wire that taps the Hyperlites into the rear accessory socket. Unplug this wire when you put the bike on the charger and plug it back in when you are ready to ride the bike. Takes about 1.5 seconds. Link to comment
EDO Posted August 6, 2006 Share Posted August 6, 2006 Quick question - with the straight Hyper-lite brake lites (no running lites), do you tap into the line feeding the original brake lites, and if yes, what is the recommended way of "tapping" the line? Thanks - Link to comment
Jon_M Posted August 7, 2006 Share Posted August 7, 2006 Quick question - with the straight Hyper-lite brake lites (no running lites), do you tap into the line feeding the original brake lites, and if yes, what is the recommended way of "tapping" the line? Thanks - If you buy the Hyperlite kit, you will find complete instructions about which wire to "tap" and all the connectors you need to complete the job without cutting or splicing wires. Link to comment
