BlueRidgeBoy Posted July 25, 2006 Share Posted July 25, 2006 I recently bought a set of SBS brake pads for my 1998 R1100RT. One was about 2 mm thicker than the other. (The metal backing plate seemed the same but the pad material was thicker on one.) When I removed my worn out pads the right pad (piston side) still had about 2 mm left and the left side was paper thin. Therefore I put the thicker one on the right. Is that correct? Link to comment
georgem Posted July 25, 2006 Share Posted July 25, 2006 You can only put the pads on one way and yes even EBC has one thicker than the other. Link to comment
