Steve Kolenda Posted July 24, 2006 Share Posted July 24, 2006 I have been fortunate enough to have purchased a brand new never been used muffler assy on E-bay for my 2000 R1100RT for $150.00. Hopefully I will be receiving it within a few days and would like to hear from someone who has done the replacement. I'm assuming it's a pretty simple task but thought I would ask if there is anything I have to be careful of and is there a seal that might need to be replace where the header meets the catalytic converter? Any advice will be greatly appreciated. Thanks in advance. Link to comment
Tony_K Posted July 24, 2006 Share Posted July 24, 2006 It's held on at just 2 points. The hanger in the back and on the header It is heavy and a bit awkward to move but can be done alone. I find using wd40 on the header connection aids in removal and installation. it will help greatly if you loosen or remove the tupperware to get it out of the way. Be mindful of the o2 sensor too. Link to comment
Steve Kolenda Posted July 25, 2006 Author Share Posted July 25, 2006 Tony, Thanks for taking the time to respond. How much tupperware would you remove and where is the oxygen sensor located? Link to comment
kioolt Posted July 25, 2006 Share Posted July 25, 2006 The oxygen sensor wire is on the right side of the bike. You will have to remove the right side tuperware to get to the plug. I seem to remember that the plug is under the tank but I am not sure of that. If it is you will have to remove the left side tuperware also so you can raise the tank. Link to comment
Joe Frickin' Friday Posted July 25, 2006 Share Posted July 25, 2006 The oxygen sensor wire is on the right side of the bike. You will have to remove the right side tuperware to get to the plug. I seem to remember that the plug is under the tank but I am not sure of that. If it is you will have to remove the left side tuperware also so you can raise the tank. Confirmed, plug is under tank; tank needs to come off for easy access. Link to comment
Tony_K Posted July 25, 2006 Share Posted July 25, 2006 I just want to add that you can remove the o2 sensor without removing a lot off plastics. Simply loosen it and unscrew it. There is enough wire to let it wind up a bit. When reinstalling pre wind the wire so as it gets screwed in it unwinds! At least this is what I have done successfully. Link to comment
