Paul Mihalka Posted July 22, 2006 Share Posted July 22, 2006 Does anybody know of a air thermometer that has a remote sensor so it does not pick up the hot sunshine on the dash? I had the Radioshack units. I liked them. They went bad between 6 month and a year, but at $10 I could do it. They are discontinued. Waterproof would be nice. The Radioshack was not. Link to comment
Global_Rider Posted July 22, 2006 Share Posted July 22, 2006 Paul, You might find one of these at the local auto parts store. I got this one at Louis in Germany, but they are quite common. It isn't waterproof, but it has been through a bit of rain without fogging up or failing. At about $5, I couldn't go wrong. I use 3M Dual Lock to hold it on. Link to comment
Paul Mihalka Posted July 22, 2006 Author Share Posted July 22, 2006 Thanks, Alex, but if the temperature sensor is inside the box and not remote, on a sunny day it is worthless. Link to comment
Shaman97 Posted July 22, 2006 Share Posted July 22, 2006 JC Whitney has a few - none are waterproof. They range from ten to twenty bucks. I tried a few marine shops - no luck. JC Whitney Temp Sensors Link to comment
Boffin Posted July 22, 2006 Share Posted July 22, 2006 Paul, one of our UK members, George, supplies to the USA a good thermometer which has a remote sensor and fits beautifully on the 1150RT. The unit display unit is compact and would mount on all sorts of other bikes. For more info see his web site. Andy Link to comment
GelStra Posted July 22, 2006 Share Posted July 22, 2006 $10 @ Pep Boys + some zip ties. Not waterproof but has survived being parked in downpours quite few times. Mounted the "outdoor" sensor down the front brake line to keep it out of the sun and ahead of engine heat. Link to comment
Draftermike Posted July 22, 2006 Share Posted July 22, 2006 I've got the same unit as GelStra but got it at Wal-Mart. Had to put a little stronger spring for more preasure against the battery but it has been working years through lots of weather. It's kinda sheltered under the dash from the harshest rains but it takes a lot of punishment. It gets so hot when temps are over a hundred something combined with heat from the oil cooler, that the read-out gets funky till it cools down, but it just keeps working. I think I get something like two years service out of a thriple A battery. Link to comment
Redbrick Posted July 22, 2006 Share Posted July 22, 2006 I used one of these digital Mini-remote units from Aerostitch ($17.00) with the sensor mounted up front under the headlight area on a K75RT and it worked well.....Mounted with velcro and zip-ties..... http://www.aerostich.com/catalog/US/Time-Temperature-p-3-c-265.html Phil..........Redbrick Link to comment
TomK Posted July 23, 2006 Share Posted July 23, 2006 Paul, I've been using the Ice Warner thermometer from JC Whitney #ZX158002A. I put the remote sensor under the mirror (after shortening the lead) which is out of the sun and as shielded from engine heat as it can be. Doesn't say waterproof but mounted next to the RID on the RT I've had no problems. Link to comment
Haynes Posted July 23, 2006 Share Posted July 23, 2006 Paul, I bought this inside-outside thermometer and fitted it under the dash on the main fairing support tube. It has an inbuilt sensor and a remote sensor that I have fitted in the nose of my RT behind the intake grille and out of the sun. I bought it here: Link to comment
Effervescent Posted July 23, 2006 Share Posted July 23, 2006 I used one of these digital Mini-remote units from Aerostitch ($17.00) with the sensor mounted up front under the headlight area on a K75RT and it worked well.....Mounted with velcro and zip-ties..... http://www.aerostich.com/catalog/US/Time-Temperature-p-3-c-265.html Phil..........Redbrick For clarification: -Eff Link to comment
Ken H. Posted July 23, 2006 Share Posted July 23, 2006 Lots of good suggestions so far. I'll throw out another. Aerostich's #4623. Two temps/voltage/clock/elapse timer. Link to comment
Paul Mihalka Posted July 23, 2006 Author Share Posted July 23, 2006 Thanks for all the tips! Hard choice indeed... Link to comment
Redbrick Posted July 24, 2006 Share Posted July 24, 2006 I used one of these digital Mini-remote units from Aerostitch ($17.00) with the sensor mounted up front under the headlight area on a K75RT and it worked well.....Mounted with velcro and zip-ties..... http://www.aerostich.com/catalog/US/Time-Temperature-p-3-c-265.html Phil..........Redbrick For clarification: -Eff Paul asking about thermometers got me to dig out the one shown here and lay it on the bike (1200RT)in the garage to check out the one on the bike...Bike shows 73 degrees, which I know is wrong..We're having a heat wave and it's still in the 80's...The other one reads 83.4, or thereabouts...Wondering why difference...Does bike have to be running?....A CANbus thingy?......Or is thermometer really that far off? Phil..........Redbrick Link to comment
