warmshed Posted July 14, 2006 Share Posted July 14, 2006 Anyone fitted a topbox to the clip on/off BMW base that fits the rear carrier? I have the BMW soft bag fitted to it at the moment but wanted to fit a hard case so my son can use it as a backrest as well as storage. I appreciate the maximum carry weight. Your experiences and fitting hints would be appreciated. Cost is a factor. Thanks Dave. Link to comment
lt8x7 Posted July 14, 2006 Share Posted July 14, 2006 BMW sell one which is made specfically to mount on the same place as the soft bag. See the photo of my bike (attached) to see what it looks like. I have been more than pleased with the one I bought. You can fit a full face helmet inside it. Link to comment
BMKrider Posted July 14, 2006 Share Posted July 14, 2006 Anyone fitted a topbox to the clip on/off BMW base that fits the rear carrier? I have the BMW soft bag fitted to it at the moment but wanted to fit a hard case so my son can use it as a backrest as well as storage. I appreciate the maximum carry weight. Your experiences and fitting hints would be appreciated. Cost is a factor. Thanks Dave. Yep I fitted a Givi 46l box and it was fine (did several European tours with it) but eventually it fell off due to the rubber on the "claws" of the BMW softcase mount wearing away. I replaced the rubber several times but eventually lost the box and mount somewhere on the road!! Far better, in my opinion, is to buy the Givi fixing kit for their box. It's rock solid and very easy to fit and use. Link to comment
hass Posted July 14, 2006 Share Posted July 14, 2006 Anyone fitted a topbox to the clip on/off BMW base that fits the rear carrier? I have the BMW soft bag fitted to it at the moment but wanted to fit a hard case so my son can use it as a backrest as well as storage. I appreciate the maximum carry weight. Your experiences and fitting hints would be appreciated. Cost is a factor. Thanks Dave. I did that and regretted it as the plastic that holds up the package carrier isn't really very strong. Cracks appeared and I had to swap the arms. So I bought the givi topbox rack instead and then a givi topbox. A much better solution! I've attached a photo of how it looked. Link to comment
autogiro Posted July 16, 2006 Share Posted July 16, 2006 Anyone fitted a topbox to the clip on/off BMW base that fits the rear carrier? I have the BMW soft bag fitted to it at the moment but wanted to fit a hard case so my son can use it as a backrest as well as storage. I appreciate the maximum carry weight. Your experiences and fitting hints would be appreciated. Cost is a factor. Thanks Dave. I did that and regretted it as the plastic that holds up the package carrier isn't really very strong. Cracks appeared and I had to swap the arms. So I bought the givi topbox rack instead and then a givi topbox. A much better solution! I've attached a photo of how it looked. I did the Givi rack and a top plate from an R1200GS so I could use my GS Vario bag on the KRS, Works well, I wish the plate was cast aluminium like the Givi though. Auto Link to comment
K12GT_Steve Posted July 17, 2006 Share Posted July 17, 2006 Anyone fitted a topbox to the clip on/off BMW base that fits the rear carrier? I have the BMW soft bag fitted to it at the moment but wanted to fit a hard case so my son can use it as a backrest as well as storage. I appreciate the maximum carry weight. Your experiences and fitting hints would be appreciated. Cost is a factor. Thanks Dave. Yep I fitted a Givi 46l box and it was fine (did several European tours with it) but eventually it fell off due to the rubber on the "claws" of the BMW softcase mount wearing away. I replaced the rubber several times but eventually lost the box and mount somewhere on the road!! Far better, in my opinion, is to buy the Givi fixing kit for their box. It's rock solid and very easy to fit and use. I did the same thing - Go Givi from the very begining! Link to comment
