Huzband Posted July 11, 2006 Share Posted July 11, 2006 I've seen Carb Stix mentioned often,but don't know where to find it. Any other recommendations? Thanks Link to comment
Chris K Posted July 11, 2006 Share Posted July 11, 2006 I use the TWINMAX sync tool. It runs around $90. If you want to save some money you can build a manometer yourself. Steve F. (RightSpin) has posted some great instructions to build one HERE . Link to comment
Boffin Posted July 11, 2006 Share Posted July 11, 2006 I use the TWINMAX sync tool. It runs around $90. If you want to save some money you can build a manometer yourself. Steve F. (RightSpin) has posted some great instructions to build one HERE . As well as being a money saver, differential manometers are self-calibrating and very accurate. Andy Link to comment
Hedge36 Posted July 11, 2006 Share Posted July 11, 2006 I use the TWINMAX sync tool. It runs around $90. If you want to save some money you can build a manometer yourself. Steve F. (RightSpin) has posted some great instructions to build one HERE . As well as being a money saver, differential manometers are self-calibrating and very accurate. Andy And dropping the TwinMax doesn't require the notification of your local HAZMAT disposal team. Link to comment
Boffin Posted July 11, 2006 Share Posted July 11, 2006 I use the TWINMAX sync tool. It runs around $90. If you want to save some money you can build a manometer yourself. Steve F. (RightSpin) has posted some great instructions to build one HERE . As well as being a money saver, differential manometers are self-calibrating and very accurate. Andy And dropping the TwinMax doesn't require the notification of your local HAZMAT disposal team. Water is Hazmat Andy Link to comment
Hedge36 Posted July 11, 2006 Share Posted July 11, 2006 The original poster mentioned CarbStix, which generally refer to diff. manometers of the mercury variety. I missed the link to the water-based unit instructions Link to comment
ShovelStrokeEd Posted July 11, 2006 Share Posted July 11, 2006 Carb Stix, from Motion Pro or others, are not differential manometers but rather the common reservoir type. Either is adequate to the task. Using water will give you roughly 13X the sensitivity of mercury which really is too much as you can drive yourself nuckin' futz trying for that last inch. Best bang for the buck is a slack tube manometer, 36" length is adequate. They are available from Dwyer Instruments for about 35 bux. You can also find them at places like WW. Grainger. I have retired my Carb Stix in favor of a Magnehelic differential vacuum gauge from the same source but, that is a high end way to go. Did it cause I can use it in my work and get free annual calibration. Scale is 30-0-30 in WC. I built some snubber sections for my lines by slipping short sections of 10-32 threaded rod into portions of the lines and the gauge is nice and stable yet sensitive enough to bring the TB's into very nice synch. Link to comment
smiller Posted July 11, 2006 Share Posted July 11, 2006 Water is Hazmat In California everything is Hazmat... Link to comment
David Posted July 11, 2006 Share Posted July 11, 2006 Any other recommendations? Yeah, give your thread a meaningful title so people don't have to open it to find out what it's about. Link to comment
bwr Posted July 11, 2006 Share Posted July 11, 2006 I use the TWINMAX sync tool. It runs around $90. If you want to save some money you can build a manometer yourself. Steve F. (RightSpin) has posted some great instructions to build one HERE . Ok, I've yet to attempt a TB synch, but would like to try it myself. Does this plastic tube/brake fluid thing really work? Or would one be better off with a Twinmax? Link to comment
tomk99r11 Posted July 11, 2006 Share Posted July 11, 2006 Some might say California is Hazmat!!!! Link to comment
russell_bynum Posted July 11, 2006 Share Posted July 11, 2006 Water is Hazmat In California everything is Hazmat... Link to comment
Huzband Posted July 12, 2006 Author Share Posted July 12, 2006 Jeez,must be a slow day for ya there,Dave. Link to comment
David Posted July 12, 2006 Share Posted July 12, 2006 Jeez,must be a slow day for ya there,Dave. Not so much. Maybe it's being in the middle of the Calgary Stampede and getting roped at the airport. For real. And speaking of which, my comment was serious. It's good discussion board courtesy to title threads so that people don't have to open them to skim the forum, and I thought I'd pass it along. No charge. Link to comment
Woodie Posted July 12, 2006 Share Posted July 12, 2006 [Does this plastic tube/brake fluid thing really work? Or would one be better off with a Twinmax? Yes it does. Advantage to a Twinmax is that it's small, and can be attached to the bike if you want to check the sync under load. The cheapo tube version is NON-mobile. More colorful, and can hang in your garage. Some people prefer the colorful fluid, and find it easier to read. Other people prefer the electronic TwinMax. Try 'em both, buy the one you like. I've had CarbStix for >10 years....they're still sealed! Done a couple of TBSyncs, both times borrowed the Twinmax that was at the Tech Day. One of these days I'll get around to syncing the carbs on my airhead, at which point I'll probably set up the CarbStix. Maybe. Link to comment
bwr Posted July 12, 2006 Share Posted July 12, 2006 Maybe it's being in the middle of the Calgary Stampede and getting roped at the airport. For real. Hey, I was just up at the Stampede over the weekend. Took in the Sunday night Chucks. Link to comment
Mike Posted July 12, 2006 Share Posted July 12, 2006 Any other recommendations? Yeah, give your thread a meaningful title so people don't have to open it to find out what it's about. Fixed by your friendly moderating team. Just a note to all--this struck me the same way. Not a huge issue, but it's kinder to folks who are trying to navigate to threads of interest to try to make your post title as transparent as possible. Link to comment
Huzband Posted July 12, 2006 Author Share Posted July 12, 2006 Sorry,folks. My mistake,& it won't happen again. BTW Dave,I mistook your first post,but your point in your second post was well received. Thanks,& apologies. Link to comment
Hedge36 Posted July 12, 2006 Share Posted July 12, 2006 The primary advantage to a TwinMax - with the obvious exception that mercury CarbStix are potentially deadly - is that you can tape it to your tank and run the bike under load at highway speeds, adjusting the right side cable adjuster as you go. Hard to do with pretty much any manometer. Link to comment
leikam Posted July 12, 2006 Share Posted July 12, 2006 Any other recommendations? Yeah, whatever vacuum measurement tool you pick, also get yourself one of Marc Parnes' throttle adjusting rings. They make getting a good sync much easier. Link to comment
smiller Posted July 12, 2006 Share Posted July 12, 2006 Yeah, whatever vacuum measurement tool you pick, also get yourself one of Marc Parnes' throttle adjusting rings. They make getting a good sync much easier. I'll second that. It's surprising what a difference that little gadget makes, allows for a much more accurate adjustment and cuts the time involved by half. Link to comment
Richard_D Posted July 12, 2006 Share Posted July 12, 2006 I've used both the Twinmax and like the Morgan Carbtune much better. It's much steadier where as the twinmax is jittery to say the least. Link to comment
Hedge36 Posted July 12, 2006 Share Posted July 12, 2006 Had a CarbTune - cool gadget, until the tubes get dirty and the slides... well, don't. Link to comment
BMT Posted July 13, 2006 Share Posted July 13, 2006 Had a CarbTune - cool gadget, until the tubes get dirty and the slides... well, don't. Just give it a clean. See the maintenance instruction in the included leaflet, or on the Morgan website. Link to comment
ShovelStrokeEd Posted July 13, 2006 Share Posted July 13, 2006 Since this particular horse is pretty well beaten to death, anybody remember "synching" the slides on our old bikes using popcicle sticks? Worked pretty darn well as a start. A little touch to one of the top adjusters afterward and off we went to await, flat tire (tubes you know), broken chain, burnt points, failed light bulbs or whatever was gonna fall off those vibrating old Brit bikes next. Link to comment
Albert Posted July 13, 2006 Share Posted July 13, 2006 Or the infamous rubber hose shoved in your ear as you oriented the other end to the front of each carb? Real precision there. Then again there wasn't much time to fiddle with carbs after all the time spent monkeying with the Lucas electrics. Link to comment
