Charles Elms Posted July 8, 2006 Share Posted July 8, 2006 What is the best tape to seal the top to the bottom of the radio box. Duct tape dries out. Electrical tape doesn't stick in the inside bends. Is there a good sticky tape that holds up well to the elements that doesn't have to be pulled tight to make a good water seal? Link to comment
kioolt Posted July 8, 2006 Share Posted July 8, 2006 I've used a good quality duct tape without any problems with drying out for three years now. If it did dry out it wouldn't be a big problem anyway since I have to remove the radio box every 18k to change the fuel filter anyway. Link to comment
Charles Elms Posted July 8, 2006 Author Share Posted July 8, 2006 Guess I've been using the cheap stuff. It doesn't last 2 months. I'll try to find some quality duct tape. Link to comment
ronest Posted July 8, 2006 Share Posted July 8, 2006 Use a cloth electrical tape, sold in auto part stores, and hardware stores. RD Link to comment
2wheelterry Posted July 8, 2006 Share Posted July 8, 2006 Charles: I don't have a radio chassis in my box anymore and did not see any issue with making this seal permanent. I used black silicone RTV between the upper and lower halves and glued them together. If I ever need to take them apart I will have a challenge, but cannot see a reason why I would. Getting rid of the cheesy looking tape was my main motivation. Link to comment
Uggles Posted July 8, 2006 Share Posted July 8, 2006 Usually called Gaffer tape by the roadies out there Link to comment
ESokoloff Posted July 8, 2006 Share Posted July 8, 2006 I used aluminum tape. Its a better "duct tape". You should be able to find it at a well stocked home improvement/hardware store in the HVAC (heating & A/C) department. You may find it offered in different thickness & it is very pricey but it is much better then "old duct tape" IMHO. I painted it after I was done. Link to comment
