KER Posted July 2, 2006 Share Posted July 2, 2006 for everyone who has ventured in replacing their clutch at home, what parts are needed? 01 21217666246 clutch housing 1 $272.00 02 21212333397 reinforcement ring 1 $11.00 03 11221341472 collar screw 5 $2.00 04 21212345597 diaphragm spring 1 $50.00 05 21212333022 pressure plate 1 $67.00 06 21217670454 clutch plate 1 $132.00 07 21212333023 housing cover 1 $141.00 08 21212332469 inner hex bolt (M6X20) 6 $2.00 these are all the parts listed at max bmw, do i need all of these or just the clutch plate. all help is appreciated! Link to comment
KER Posted July 2, 2006 Author Share Posted July 2, 2006 im still looking but could also use some help, im also looking for the part # for the clutch neutral switch. Link to comment
Shaman97 Posted July 2, 2006 Share Posted July 2, 2006 I had a similar post a while back that resulted in a nugget of information. Depending on your bike's manufacturing date, you may be better off buying the 'kit' for the clutch replacement. Here's the thread I made a few adjustments to my clutch - now it's working fine. Good luck on yours. Bob Link to comment
Stan Walker Posted July 2, 2006 Share Posted July 2, 2006 what parts are needed? You won't really know until you take it apart. You could add an input shaft to the "all the parts" list..... And a slave cylinder too. If I were opening an 1150 RT for a known clutch issue, I would have the clutch disc, diaphragm spring, the 6 screws, and a clutch slave cylinder on hand before I started the tear down. I would buy other parts only if needed. Stan Link to comment
