kltk165 Posted July 1, 2006 Share Posted July 1, 2006 Does anyone know if Ram-mount has a ball that attaces to the mirror mount hole on the clutch/brake lever housings? If so, can you give me a part #? I wanna add a SkyFi to my '96 LT. Link to comment
ESokoloff Posted July 1, 2006 Share Posted July 1, 2006 Find here. I hope this works for your bike/unit???? Link to comment
pieceofficer Posted July 2, 2006 Share Posted July 2, 2006 The link Eric gave you is about the best way to go. They do make a mount for the mirror housing, however, you will have to provide your OWN bolt and buy just the ball from Cyclegadgets or R-A-M youself. You may want to consider R-A-M's Aqua box as well. I use the mount on the reply above and where they have the antenna, I mounted a ball there, and then an arm and my Ipod off to the side, so I have both coming off that mount, I use an Audiovox Xpress reciever, but should mount the same. Bill Link to comment
