STL RT Rider Posted June 28, 2006 Share Posted June 28, 2006 Any ideas on removing an ugly decal from an aftermarket screen? I've tried soaking it, using heat gun, nothing seems to loosen it. It looks like a typical decal, the type you would apply by soaking it, applying and letting it dry. I've got some of that "Goo Gone" stuff for removing things like stickers, but I'm afraid it will ruin, or at the very least discolor, the acrylic screen. Any ideas would be greatly appreciated. Thx! Link to comment
Hedge36 Posted June 28, 2006 Share Posted June 28, 2006 Lighter fluid, as in Ronsonol. Use liberally and don't smoke Link to comment
magnum Posted July 1, 2006 Share Posted July 1, 2006 Try a single side razor blade with vaseline. Vaseline keeps the blade from digging in and seems to soften the glue. Link to comment
RCE1 Posted July 1, 2006 Share Posted July 1, 2006 I doubt that goo-gone, the orange oil based solvent, will harm your screen. It is always pretty high on my list of not-too-agressive solvents to try. Goof Off, on the other hand, will trash the plastic for sure. You might consider steam from an electric kettle, being sure not to overheat the plastic and melt it. Sometimes moist heat like that will succeed where neither water nor dry heat from a heat gun does the job. Good luck. I hate stickers on my stuff and ususally the first thing I do when I get home is remove the BNG (Bold New Graphics). Link to comment
ben1364 Posted July 1, 2006 Share Posted July 1, 2006 Another suggestion is to heat the decal (not too hot!) with a hair dryer then use a fingernail to lift one edge of the decal. Once lifted about 1/4th inch, hold the lifted edge with pliers and apply more heat to soften the adhesive and continue to slowly pull the decal from the windscreen. Clean up with citrus solvent follwed by a solution of dishwashing detergent and polish. Link to comment
FrankT Posted July 1, 2006 Share Posted July 1, 2006 To remove the decal on my Aeroflow, I first heated the decal with a hair dryer until I could get a grip on an edge and pulled gently. I was able to remove it in one piece. Then, I used 3M Adhesive, Tar and Wax Remover to remove the residual adhesive. You woulda never known there was a decal there to begin with. Link to comment
Reddog900 Posted July 2, 2006 Share Posted July 2, 2006 Once you get the decal off you can also use some waterless hand cleaner, Goop works good. Don't use the stuff that has granulated pumic, it might scratch the screen. Good Luck. Link to comment
STL RT Rider Posted July 12, 2006 Author Share Posted July 12, 2006 Thanks for the ideas. I tried all the above and none worked. Time to find another ugly sticker to cover the uglier one! Link to comment
velomoto Posted July 13, 2006 Share Posted July 13, 2006 The local BMW dealership cautioned me to NOT use a power washer on my 12RT as it could remove the decals from the tupperware... Good luck! Greg Link to comment
