preacher53 Posted June 28, 2006 Share Posted June 28, 2006 I just purchased my connector for the power scoket on the 2006 RT. The rear socket works fine but the front does nothing. Anyone had this problem or know of how to go about fixing it? I know it would be under warranty but if I could fix it myself it would save the hassle. Im leaving Sunday to go on 2 week trip on bike. Link to comment
MichaelC Posted June 28, 2006 Share Posted June 28, 2006 Get a Torx driver and take off the left front body panel - there are Torx screws below the instrument cluster, below the power outlet, and on the inside of the bodywork near the front forks. The body panel will be held captive by the wiring for the accesory outlet, which is on a connector that can be removed by squeezing. Remove the connector. Turn bike ignition on, and using a multimeter, measure the voltage present on the two wires of the connector. On my bike, this is 12.4 V. Start the bike and while running in neutral, verify that the voltage remains present on the wire pair. If there is voltage present on the wire pair, perhaps the connector worked itself loose. Replace the connector and before reattaching bodywork, try the outlet. If no voltage present, it is a CAN-related problem? Link to comment
Limecreek Posted June 28, 2006 Share Posted June 28, 2006 Pull the upper fairing off and make sure the wire harness is completely plugged into the socket. The technician may have left it unplugged after your last service. Link to comment
ben1364 Posted June 28, 2006 Share Posted June 28, 2006 Yours sounds like the likely answer. Been there. Done that! <g> Link to comment
preacher53 Posted June 29, 2006 Author Share Posted June 29, 2006 That was the problem. It was unplugged and was an easy fix. Thanks for the info. Link to comment
