Waterman Posted June 27, 2006 Share Posted June 27, 2006 I have bought some bar racks to raise the handlebars up and back about one inch. Has anybody had problems with this that would be good for me to know about? I have been told to check the brake line and make sure it is not in a strain or being pulled. Link to comment
David Posted June 27, 2006 Share Posted June 27, 2006 As I recall, there's a nut on the underside of a couple of those bolts that affix the handlebars to the triple clamp. I think I figurd that out the hard way. Are you sure you need them? Make sure you fix your posture before you go messing with the bike's ergonomics. Link to comment
smiller Posted June 27, 2006 Share Posted June 27, 2006 Check that the bar backs do not contact the tank when the steering is at full lock. Link to comment
John Dickens Posted June 28, 2006 Share Posted June 28, 2006 As I recall, there's a nut on the underside of a couple of those bolts that affix the handlebars to the triple clamp. I think I figurd that out the hard way. The 2 bolts with nuts on the back are the ones which have the wire loop cable tidy on them. They are self locking nuts and can chew up the bolt threads when you remove them. The bolts can then chew the thread in the alloy. You may need to cut a couple of ty-wraps to free the wiring then re-tie them when you've finished. All the cables and the brake hose should have enough slack to handle the barbacks. Link to comment
tomk99r11 Posted June 28, 2006 Share Posted June 28, 2006 I put some on my 99 and later took them off. Very straight forward to install, no big deal at all. The windscreen switch did hit my tank bag when the bars were turned nearly to left side lock, but that is not much of a deal either. Link to comment
Waterman Posted June 28, 2006 Author Share Posted June 28, 2006 Thanks! Did you have any trouble with self-locking nuts..? That has been mentioned. Link to comment
Charles Elms Posted June 28, 2006 Share Posted June 28, 2006 Take the self locking nuts off first. Link to comment
