New1200RTRider Posted June 26, 2006 Share Posted June 26, 2006 Going to Synchronize my throttle bodies for the first time and have a question to anyone who has done it. one throttle body has a cap on the vacuum inlet which is easy to figure out but the other throttle body has a hose plugged into it. Does it affect the motor if you unplug that hose and just plug it doing the sync? Thanks Link to comment
cjmkerns Posted June 26, 2006 Share Posted June 26, 2006 Don't even need to plug it while you are doing the sync. That hose draws vapors through a solinoid valve from your charcoal canister at mid to higher RPM's and burns them in the left cylinder. Regards Carl Link to comment
