Retired At LAst Posted June 23, 2006 Share Posted June 23, 2006 I want to replace the oil cap rubber washers on my rt. The smaller one on the cap itself is self explanatory. However, the lager inner one is giving me a problem. How do I remove the plastic piece to put the new washer on. Thanks. Link to comment
Boffin Posted June 23, 2006 Share Posted June 23, 2006 Just pull it out. I find I can get mine out with my index finger. Andy Link to comment
jojo Posted June 23, 2006 Share Posted June 23, 2006 i use a flat head screw driver and gently lift the filler pipe by the bit that sticks out to prevent the pipe to rotate Link to comment
DEF Posted June 23, 2006 Share Posted June 23, 2006 I assume you mean the O-ring that sits on the flange on the removable oil filler cap. If this is the one, just pull it off and insert the new one. If you mean the O-ring under the plastic insert in the valve cover, remove the valve cover and press out the plastic insert. Fit the new O-ring and reinstall the plastic insert. Link to comment
