JByerly Posted June 21, 2006 Share Posted June 21, 2006 Can anyone tell me if 1150 gs cases will fit an 1100 rt? Thanks Jerry Link to comment
KER Posted June 22, 2006 Share Posted June 22, 2006 the regular system case will go between the bikes. I have taken the bags from my 1150GS and move them to me 1150RT without issues. And have also moved some bags from an 1100RT to an 1150GS, they should move over without a problem. Link to comment
David Posted June 22, 2006 Share Posted June 22, 2006 Well, I must be wrong, then. But I could swear that we tried that with the late Bill Hawkins' 1150 GS and my RT. If I've steered someone wrong, my apologies. Link to comment
Lone_RT_rider Posted June 22, 2006 Share Posted June 22, 2006 Well, I must be wrong, then. But I could swear that we tried that with the late Bill Hawkins' 1150 GS and my RT. If I've steered someone wrong, my apologies. David, You might be thinking of putting RT bags on the GS? The RT bags don't have the cut-out for the high pipe on the GS. The GS bags will however go on the RT since there are no pipe clearance issues. Rainy has the same problem with her R1100R and its high pipe. It shares the same left side bag as the R11XXGS. Shawn Link to comment
KER Posted June 22, 2006 Share Posted June 22, 2006 Well, I must be wrong, then. But I could swear that we tried that with the late Bill Hawkins' 1150 GS and my RT. If I've steered someone wrong, my apologies. David, You might be thinking of putting RT bags on the GS? The RT bags don't have the cut-out for the high pipe on the GS. The GS bags will however go on the RT since there are no pipe clearance issues. Rainy has the same problem with her R1100R and its high pipe. It shares the same left side bag as the R11XXGS. Shawn I should note that my Gs was a GS-P and had a lowered pipe on it that was part of the police kit that was on it, so i used normal system cases that did not have the left sit fitted around the exhaust. Link to comment
