millbert Posted June 19, 2006 Share Posted June 19, 2006 I got one side of the rear tire bead broke,go to break the other side and the broke side squeezes together while the side that isn't broke,does not move. What am I doing wrong? Flipped the tire around, made no difference.I'm using this method: http://www.clarity.net/~adam/tire-changing.html (step 4) Link to comment
Scotty Posted June 20, 2006 Share Posted June 20, 2006 If you are doing this on the ground, work bench or other flat surface, make sure your rim is elevated. Once you flip the wheel over, the rubber with the broken bead cannot be resting on anything. That will give it room to get out of the way when you break the second bead. I hope that makes sense. Link to comment
oreana123 Posted June 20, 2006 Share Posted June 20, 2006 Right, make sure you block under the rim to get clearance for the rotor(s). I just put a new set of tires on my bike. Two things mage it very nuch easier: put your rim and tire as well as the new tire out in the sun until it is hot and use armor-all or the like for a lubricant. I was able to break the bead on my front tire by pushing in very hard with a rounded point of hard plastic! John S Boise on new Metzlers Link to comment
Thatman Posted June 20, 2006 Share Posted June 20, 2006 Napa does sell tire mounting lubricant in gallon containers. It's like $10 and it has lasted me for over 3 years. Link to comment
millbert Posted June 20, 2006 Author Share Posted June 20, 2006 Thanks Scotty and Oreana 123, I let the tire sit in the sun all day,-the warm tire made a big difference-lubed the hell out of it,with soap and water, coca-cola and mounting lubricant that I got off of a tire guy at work. Tack welded a 14" rim to a steel plate on the floor, pushed down with a 6" ram on a port-a-power jack, on the unbroken bead, came off like nothing! Last night an old trucker who changed a lot of tires said they used to use coca-cola for a lubricant to break a bead, must be something in the old coke formula,'cause it doesn't work now ...ask me how I know. One thing wrong was the jig I made to hold the jack, it didn't have a long enough stroke...to be corrected in the future. Well, gotta go clean the garage floor and put the new tire on.... Link to comment
