NormR Posted November 22 Posted November 22 Hi All, Looking for the inside & outside diameters for the oil drain Crush Washer on my 1250. I want to order some online TIA Norm
Boxflyer Posted November 22 Posted November 22 It would be simple to just list the crush washer as aluminum 20x24…but there is so much more to know from this document. https://www.realoem.com/bmw/enUS/showparts?id=0J63-USA-11-2019-K52-BMW-R_1250_RT_19_0J61,_0J63_&diagId=02_0103 Lots of these are available in bulk quantities from Amazon. K52 (R 1200 RT, R 1250 RT) R 1250 RT 19 (0J61, 0J63) Engine oil / maintenance service Select another vehicle > Service and scope of repair work > Engine oil / maintenance service No. Description Supp. Qty From Up To Part Number Price Notes 01 Oil filter 1 11427721779 $21.84 02 Gasket ring A20X24-AL 1 07119963340 $0.38 03 Screw plug, magnetic M20X1,5 1 11118530317 +core 05 Screw with bush 6 11128523552 06 O-ring 27X3,2 1 07119904950 $3.10 07 Gasket ring A16X20-AL 1 07119963252 $0.57 08 Screw plug M16X1,5 1 07119902292 $2.83 09 Gasket ring A12X16-CU 1 07119963132 $0.38 10 Screw plug M12X1,5-ZNNIV 1 07119904550 $8.15 11 O-ring 11,2X1,8 1 33117695219 $1.67 12 Oil drain plug M12X1-ZNNIVSI 1 33117705854 $14.84 13 Spark plug NGK LMAR8D-J 2 12128532942 +core 14 Air filter element 1 13727726799 15 Boot 1 32728532636 Handbrake lever Handbrake lever 16 Countersunk screw ISA M4X16 A2-70 4 32727681032 $1.39 17 Boot 1 32728532966 Clutch lever 18 PT screw 4X22 4 32728534149 19 Boot 1 32727722873 20 Motor oil ADVANTEC 5W-40 1L X 83212365958 21 Hypoid axle oil G3 0,5L X 83222460128 21 Hypoid axle oil G3 60L X 83222471423 22 Transmission oil Hyspin V10 250 ML X 21522455540 23 Radiator/antifreeze/anti-corrosion agent 1,5L X 83512445463 24 Brake cleaner 2.0 500ML X 83192445462 For vehicles with National version China Y770A=Yes 24 Brake cleaner 2.0 500ML X 83192406954 25 Brake fluid DOT4 LV, low viscosity 1L X 83132445461 25 Brake fluid DOT4 LV, low viscosity 250ML X 83132467961 Notes +core = plus core charge (possibility of a return of the old part) 3
PeterBaumgart Posted November 22 Posted November 22 6 hours ago, NormR said: Hi All, Looking for the inside & outside diameters for the oil drain Crush Washer on my 1250. I want to order some online TIA Norm I've been running a "scientific experiment" with all my sealing washers and o-rings by just cleaning them, inspecting for damage, and if none found, happily reusing. I think my main oil drain washer is now on its 5th cycle. No indication of any leaks! (So far... Staying open minded, will report if findings change. :-)
NormR Posted November 22 Author Posted November 22 11 minutes ago, PeterBaumgart said: On my old 1st Gen FZ1 I only torqued the drain bolt to spec and NEVER used a crush washer actually! I'm trying to be a proper BMW owner now and follow all the correct protocols lol I've been running a "scientific experiment" with all my sealing washers and o-rings by just cleaning them, inspecting for damage, and if none found, happily reusing. I think my main oil drain washer is now on its 5th cycle. No indication of any leaks! (So far... Staying open minded, will report if findings change. :-)
lkraus Posted November 23 Posted November 23 I maintained cars, trucks, motorcycles, and mowers for hundreds of thousands of miles over 45 years before the internet informed me that crush washers should be replaced after each use. Many of those vehicles had oil changes every 3000 miles, so some washers were reused 40-50 times. Never had a leak, even the time or two that I inadvertently installed the drain plug without a washer at all. Some of the filters I've bought online came with washers, most of them are hanging on a pegboard hook over my bench. 2
NormR Posted November 23 Author Posted November 23 34 minutes ago, lkraus said: I maintained cars, trucks, motorcycles, and mowers for hundreds of thousands of miles over 45 years before the internet informed me that crush washers should be replaced after each use. Many of those vehicles had oil changes every 3000 miles, so some washers were reused 40-50 times. Never had a leak, even the time or two that I inadvertently installed the drain plug without a washer at all. Some of the filters I've bought online came with washers, most of them are hanging on a pegboard hook over my bench. Damn :p I just ordered a dozen crush washers for my 1250! I guess I will be "over compensating" and be very vigilant and use one each time I change my oil for the next few years lol 3
Skywagon Posted November 23 Posted November 23 3 hours ago, Rougarou said: People actually replace those I thought you got a free one with every purchase of Rotella 😁 1
Rougarou Posted November 23 Posted November 23 2 minutes ago, Skywagon said: I thought you got a free one with every purchase of Rotella 😁 No, I just flip it over each oil change, you know, re-crush it.......I'm frugal that way. 1 2
TEWKS Posted November 23 Posted November 23 10 hours ago, Rougarou said: No, I just flip it over each oil change, you know, re-crush it.......I'm frugal that way. Yeah, kinda just like toilet paper. 5 1
Hosstage Posted November 23 Posted November 23 Can the washer be annealed to return the crush function?
Rougarou Posted November 23 Posted November 23 29 minutes ago, TEWKS said: Yeah, kinda just like toilet paper. Not exactly, but close 1
Scotto336 Posted November 23 Posted November 23 Oh no, a crush washer thread! Well, here's my 2 cents: The objective in achieving a seal is to apply a sufficient clamping force such that the contact compressive stress (force divided by surface area) at the seal joint is higher than the pressure trying to push fluid past the seal. Unfortunately, tightening torque can’t be directly translated into contact compressive stress due to the large, and variable contributions of friction at the washer/fastener head interface and on the threads. Recommended torques are specifically designed to achieve sufficient clamping force without risking stripped threads. The one potential value of using a fresh, malleable washer is that it might help address surface imperfections by forming around or into them. So… with perfectly smooth surfaces, and equal washer dimensions, an old washer should seal just as good as a new one with equal clamping force. Those who have reused washers forever can attest to that. If the washer has crushed into larger surface dimensions, then the clamping contact stress be a bit less due to the larger surface area, but this area would likely be the same when first used and re-used, so no real difference. If the casting surface is not smooth (rare these days) then a new, malleable washer would be a better choice. So…what do I do? My standard practice is to accidently drop the hot drain plug into the hot oil pan where the washer has a chance to join up with all the other washers at the bottom of the pan. Then I retrieve it with a magnet and put on a new washer. 1
Bernie Posted November 23 Posted November 23 I have several used, ahem experienced Crush Washers for sale for the different RT's I owned over the years. No corrosion and stored above sea level. Plus shipping. 1 2
wbw6cos Posted November 24 Posted November 24 What kind of warranty do you offer with those, Bernie? (asking for a friend) 1
JCtx Posted November 24 Posted November 24 Last time I changed the oil, just sanded the crush washer with grit-400 sandpaper, since I couldn't find my spare crush washers. That's an option, if caught without a new one. And yes, ordered more for future times. By the way, was surprised to see the spark plug LMAR8D-J also called out for 1250s on the chart above. My '20 bike came with LMAR8AI-10s, which I just dumped for the D-Js, so I don't have to worry about the AI tips falling inside my engine. So maybe that was just in the US market? Just curious. By the way, that realoem site only goes to 2019 and 2020. Just a little behind the times. Ha ha.
NormR Posted November 24 Author Posted November 24 Never thought my thread would generate so many responses :p Absolutely a hoot to read. 1
Rougarou Posted November 24 Posted November 24 31 minutes ago, NormR said: Never thought my thread would generate so many responses :p Absolutely a hoot to read. That's cause many here are over thinkers and paranoid concerning maintenance. 1 2
TEWKS Posted November 24 Posted November 24 18 minutes ago, Rougarou said: That's cause many here are over thinkers and paranoid concerning maintenance. If you hadn’t flipped that crush washer so many times you may of seen 200K on your RT.
Rougarou Posted November 24 Posted November 24 9 minutes ago, TEWKS said: If you hadn’t flipped that crush washer so many times you may of seen 200K on your RT. I think it has more to do with not checking the air pressure in the tires regularly. 1
Bernie Posted November 24 Posted November 24 13 hours ago, wbw6cos said: What kind of warranty do you offer with those, Bernie? (asking for a friend) Standard BMW warranty, if they leak it must be operator error or you used the wrong oil. 1 3
TEWKS Posted November 24 Posted November 24 1 hour ago, NormR said: Never thought my thread would generate so many responses :p Absolutely a hoot to read. Well, it’s not an oil thread but close. What’d ya expect? 1
wbw6cos Posted November 24 Posted November 24 Maybe used crush washers are sealed well with the use of Rotella. 1
Dave_in_TX Posted November 24 Posted November 24 14 hours ago, JCtx said: By the way, was surprised to see the spark plug LMAR8D-J also called out for 1250s on the chart above. Interesting. However, the parts fiche at Max BMW shows the the plug to be an LMAR8-AI10.
Rougarou Posted November 24 Posted November 24 3 hours ago, wbw6cos said: Maybe used crush washers are sealed well with the use of Rotella. 1
JCtx Posted November 24 Posted November 24 Oh, okay; thanks. But I think that proves what you said: That they're interchangeable. And I already put them on my bike, so if it explodes, it'd be your fault. Take care.
AviP Posted November 27 Posted November 27 On 11/22/2024 at 4:34 PM, PeterBaumgart said: I've been running a "scientific experiment" with all my sealing washers and o-rings by just cleaning them, inspecting for damage, and if none found, happily reusing. I think my main oil drain washer is now on its 5th cycle. No indication of any leaks! (So far... Staying open minded, will report if findings change. :-) My Subaru has had an oil change every 6000 miles with the original crush washer. It has never leaked. I am at 221,000 miles now. 3
Dave_in_TX Posted November 28 Posted November 28 On 11/24/2024 at 10:31 AM, Dave_in_TX said: Interesting. However, the parts fiche at Max BMW shows the the plug to be an LMAR8-AI10. I've been running LMAR8D-Js in my 2023 GS for over 30k miles without problems.
Bernie Posted November 28 Posted November 28 6 hours ago, Dave_in_TX said: I've been running LMAR8D-Js in my 2023 GS for over 30k miles without problems. Well once you have done over a 100k miles in testing, let us know. 2
Scotto336 Posted November 28 Posted November 28 So in conclusion, BMW drain plug washers can last significantly longer than BMW driveshafts, but you will have to bear the cost if they ever need replacing. 2 5
