rubber part of gear shift lever replacement 2000 R1100RT
Mark Montgomery
Mark Montgomery
Posted (edited)
Does anyone know how to remove the rubber part of gear shift lever 2000 R1100RT?
Edited by Mark Montgomery
incorrect part name
  • Mark Montgomery changed the title to rubber part of gear shift lever replacement 2000 R1100RT
King Herald
Posted
A sharp knife?
Posted
Morning Mark
You can cut it off but it   c-a-n   be removed with some effort & ingenuity.
I have removed them before by using a small screwdriver inserted between the outer end or the rubber & the expanded end of the shift lever.
Once the screwdriver is inserted then  spray  rubber lube, soapy water, or even WD-40, into the gap provided by the screwdriver.
Then start turning the rubber while pulling outward (leave the screwdriver in place). If enough lube is used (personally I use a dedicated rubber lube) you can start working the rubber over the expanded end of the shift lever post like a tire machine removes a tire.
Sometimes they will spin/pull right off & other times it will test you.
