kruuuzn Posted May 7 Share Posted May 7 I want to perform an oil change on a 1981 R100RS. The bike was left to me by a friend and I don’t have any paperwork or manuals. I’m assuming the bike has an oil cooler because there’s a couple of line fittings on the plate on the right side of the motor near the front. Is this correct? Is it a complicated job to change the filter? And where’s the best place to buy a filter kit? Thanks. Link to comment
Michaelr11 Posted May 7 Share Posted May 7 If your bike has an oil cooler - you should see one in the front of the bike. The correct oil filter kit is a Mahle OX36D. The "D" is the kit, exactly the same as the BMW kit, with a bag of crush washers, and gaskets. The 36 is the "long" filter, which the bikes with oil coolers use. First time, you could call a BMW dealer - if there's one nearby - and order one from them. Link to comment
kruuuzn Posted May 7 Author Share Posted May 7 Thanks Micheal. Yup, I see a oil cooler in the front of the fairing. I found a supplier in NC that had the filter kits in stock. Another question: what's the proper way to check the oil level? Do you screw the dip stick all the way in or just let the threads rest on the engine case? Link to comment
Michaelr11 Posted May 8 Share Posted May 8 Are you in NC? Wipe off the dipstick, then insert it until the cap rests at the top of the case. Don’t screw it in. Bike on the center stand or held up. Now that you got one, if you check Rock Auto dot com, you can find the Mahle oil filter kit, as well as the Mahle air filter. Link to comment
kruuuzn Posted May 8 Author Share Posted May 8 No, I’m in northern Michigan. I just happened to find boxer2valve.com while searching for the filter kit. They had the exact Mahle part number that you gave me and I confirmed my specific bike on their website. Link to comment
