Kilrush R1150RT Posted December 18, 2022 Share Posted December 18, 2022 Hi there. I just bought a F650 GS (2004) and the rear shock adjuster appears to be difficult to turn. What am I doing wrong? (do I need to pull or push it or something - ie childproof protection :)? ) thanks Link to comment
dirtrider Posted December 18, 2022 Share Posted December 18, 2022 2 hours ago, Kilrush R1150RT said: Hi there. I just bought a F650 GS (2004) and the rear shock adjuster appears to be difficult to turn. What am I doing wrong? (do I need to pull or push it or something - ie childproof protection :)? ) thanks Morning Kilrush R1150RT It should be pretty straight forward, (see info below) It is possible the adjuster is out of (or low on) fluid so someone in the past might have forced the adjuster knob all the way tight in one direction or the other. Can you still see the position indication decal? If so that can give you an idea on which way it needs to be moved or adjusted. Link to comment
Kilrush R1150RT Posted December 18, 2022 Author Share Posted December 18, 2022 8 hours ago, dirtrider said: Morning Kilrush R1150RT It should be pretty straight forward, (see info below) It is possible the adjuster is out of (or low on) fluid so someone in the past might have forced the adjuster knob all the way tight in one direction or the other. Can you still see the position indication decal? If so that can give you an idea on which way it needs to be moved or adjusted. Thanks Dirtrider. I will have a look tomorrow. As always you have the solution. I think it is turned all the way in. So I need to turn clockwise I think. Can I get a copy of this manual somewhere? Thanks mate Link to comment
dirtrider Posted December 18, 2022 Share Posted December 18, 2022 22 minutes ago, Kilrush R1150RT said: Thanks Dirtrider. I will have a look tomorrow. As always you have the solution. I think it is turned all the way in. So I need to turn clockwise I think. Can I get a copy of this manual somewhere? Thanks mate Evening Kilrush R1150RT Yes, BMW makes that available. Look in your Messages on this site, I will send it to you. 1 Link to comment
Kilrush R1150RT Posted December 19, 2022 Author Share Posted December 19, 2022 Dirtrider Thanks! Link to comment
