Mike05 Posted June 1, 2006 Share Posted June 1, 2006 Anyone know where to buy these two items ( Centech AP-1 Fuse Panel & AP-170R Relay )? The Centech home page has the fuse box but no referrence to the relay. Likewise in other locations; would prefer to get them together from the same supplier. While I'm asking, are these the only two "wiring" items I need in order to add some electrical accessories (ex: PIAA 1100's) to the R1200RT? Mike05 Link to comment
brennaman Posted June 1, 2006 Share Posted June 1, 2006 I just installed a set of PIAA's on my rt today, but I did not add another fuse box. The PIAA's should have come with a fuse, and you wire it directly up to the battery. Then those comming off of the battery go to the light thru the relay that came with the lights. I found the 12 volts for the relay in my fuse box. The only thing that I added was and autoswitch as opposed to using the on/off switch supplied with the lights. It is not necessary, but I just thought it would be a little cleaner install. http://autoswitch.com/ here is a description of the autoswitch I used, you would have to see which one is used on your bike, I have an 1150RT, the 1200 uses a different one. Everything you need should have been supplied with the lights, other than something to mount them to the bike with. Phil Link to comment
jimswms Posted June 2, 2006 Share Posted June 2, 2006 here ya go http://www.maxbmwmotorcycles.com/fiche/C...p;model=R1200GS Link to comment
Mike05 Posted June 2, 2006 Author Share Posted June 2, 2006 Jim, Thanks for the heads up; ordered the Centech fuse panel & relay from them this morning. Nice folks. BTY, my wife & I are both originally from Rhode Island and plan to be on vacation in Pettasquamscutt down by Narragansett Bay in early August. I'll be sure to give you a call. Thanks again, Mike05 Link to comment
