christianf Posted December 9, 2022 Share Posted December 9, 2022 Can someone explain to me how to access the preload setting on my 2006 r1200 rt thank you Link to comment
lkraus Posted December 9, 2022 Share Posted December 9, 2022 If it has the standard adjuster, there should be knob under the seat. If it has ESA, you select from three settings using the button on the left handle bar, engine running, in neutral. When mine still worked, I made adjustments while standing next to the bike to reduce the load on the motor. Instructions are in the owners manual, page 61 for manual adjust, page 63 for ESA. Link to comment
christianf Posted December 14, 2022 Author Share Posted December 14, 2022 Thank you but I cannot find the hand wheel or the spring screw. I looked all over under the seat but no ha wheel and I do not know how to access the spring preload adjusting scre. Do I need to remove the fairing? Link to comment
dirtrider Posted December 14, 2022 Share Posted December 14, 2022 13 hours ago, christianf said: Thank you but I cannot find the hand wheel or the spring screw. I looked all over under the seat but no ha wheel and I do not know how to access the spring preload adjusting scre. Do I need to remove the fairing? Afternoon christianf Look closely at your rear strut (rear shock) to see if it has a big box looking thing on the side near the top if it does then you will have no manual rear adjuster) the adjuster will be electrical with the switch to adjust on the L/H handlebar pod. Link to comment
christianf Posted December 22, 2022 Author Share Posted December 22, 2022 Thank you I will look at this. Is this part of the traction assist mode setup? I have three levels, normal, sport and rain Link to comment
dirtrider Posted December 22, 2022 Share Posted December 22, 2022 2 minutes ago, christianf said: Thank you I will look at this. Is this part of the traction assist mode setup? I have three levels, normal, sport and rain Morning christianf No the traction control is a different system that controls the powertrain not the suspension. Link to comment
christianf Posted December 24, 2022 Author Share Posted December 24, 2022 I do havé that contraption on the side of the rear shock similar to your picture. I also have a ESA button on my left handlebar, I believe this is electronic suspension assist correct? Link to comment
lkraus Posted December 24, 2022 Share Posted December 24, 2022 The 2006 RT ESA provides three rear preload settings (one helmet, one helmet+luggage, two helmets) and three damping settings (comfort, normal, sport). There was no rain mode and the only thing that might be considered traction control on 2006 RT would be ABS. Automatic Stability Control (ASC) became available in 2007, but that has no modes, it is either on or off, Link to comment
dirtrider Posted December 24, 2022 Share Posted December 24, 2022 10 hours ago, christianf said: I do havé that contraption on the side of the rear shock similar to your picture. I also have a ESA button on my left handlebar, I believe this is electronic suspension assist correct? Morning christianf Close, you have what BMW calls ESA (E)lectronic (S)uspension (A)djustment. Look in your riders manual at around pages 63 to 65 for ESA settings & understanding. Link to comment
christianf Posted December 24, 2022 Author Share Posted December 24, 2022 If I understand correctly there are three modes related to loading and their modes related to driving styles. Each of the 9 combinations adjusting the suspension “geometry” per the manual description. Interesting but no traction control per se. Is there one combination that would be more adapted to rain mode? Thank you for your help clarifying all this Link to comment
dirtrider Posted December 24, 2022 Share Posted December 24, 2022 1 hour ago, christianf said: If I understand correctly there are three modes related to loading and their modes related to driving styles. Each of the 9 combinations adjusting the suspension “geometry” per the manual description. Interesting but no traction control per se. Is there one combination that would be more adapted to rain mode? Thank you for your help clarifying all this Afternoon christianf Nothing on the 2006 1200RT specifically related to rain riding or wet traction. The ABS braking should give you some wet road stopping security if you are riding straight up but even the ABS system on the 2006 1200RT isn't going to always prevent issues if hard braking while the motorcycle is leaned over. Link to comment
