tgvortex Posted December 2, 2022 Author Share Posted December 2, 2022 BC button failed. Can it be serviced, or replaced, or do I have to get entire unit. Link to comment
dirtrider Posted December 2, 2022 Share Posted December 2, 2022 9 minutes ago, tgvortex said: BC button failed. Can it be serviced, or replaced, or do I have to get entire unit. Afternoon tgvortex Is it an actual push button failure or possibly a broken wire from the switch to main harness? If a broken wire (from handlebar movement flexing) then even a new switch won't help. Those handlebar push button switches are a foil type affair so contact cleaner or lube usually doesn't help (you can try a shot of contact cleaner then working the button but doubtful that it will help or last) Link to comment
