Alba Posted November 27, 2022 Share Posted November 27, 2022 As I was putting new tyres on the bike I decided to grease my FD, I used the below YT for guidance. My FD looks shit and is not dropping off, see photo. Should I bolt back together and forget as it's not part of any BMW service schedule or should I continue? If I do continue how do I get it off?? Also while trying to pull the final drive off a rubber fitment hit the floor, any idea where it comes from? Link to comment
MikeB60 Posted November 27, 2022 Share Posted November 27, 2022 There is a service campaign regarding this issue in the USA. Given the condition of your drive shaft, it would be replaced over here. Might want to check with a dealer to see if BMW might address the issue. 1 Link to comment
Boxflyer Posted November 27, 2022 Share Posted November 27, 2022 The little rubber part you found is #7 in this RealOEM diagram. Final drive Breather 1 Link to comment
Alba Posted November 27, 2022 Author Share Posted November 27, 2022 After looking at some more YT I decided to 'rotate the housing' a bit harder and it came off. Tided up the splines lubed with loads and she's running fine. I will raise the rust with the dealer though. Link to comment
Alba Posted January 17, 2023 Author Share Posted January 17, 2023 I would like to resurrect this thread for a follow up question. Should I do the gearbox end or, as it's not in any maintenance schedule, leave it alone? Link to comment
