SANTA Posted October 25, 2022 Share Posted October 25, 2022 I have the opportunity to buy a very low mileage r1150r, id actually was searching for a r1200r but this just popped up 2004, 15k km been in storage for 5 yrs. it was pulled out of storage earlier this summer and has been in use,. my only concern is what effect sitting for 5 yrs would have on the nickasil lining in the bore? my previous experience with a 2003 r1100s means that theres not much on this bike i haven't had to deal with, so whats the verdict? Link to comment
dirtrider Posted October 25, 2022 Share Posted October 25, 2022 7 hours ago, SANTA said: I have the opportunity to buy a very low mileage r1150r, id actually was searching for a r1200r but this just popped up 2004, 15k km been in storage for 5 yrs. it was pulled out of storage earlier this summer and has been in use,. my only concern is what effect sitting for 5 yrs would have on the nickasil lining in the bore? my previous experience with a 2003 r1100s means that theres not much on this bike i haven't had to deal with, so whats the verdict? Morning SANTA The nikasil cylinder lining will probably be the least of you worries as not much can damage it. I have seen a number of improperly long-term stored BMW boxer bikes & haven't seen the cylinder walls as being a problem. I would be way more worried about the fueling system parts due to long term storage with alcohol containing gasoline. Just because they got it running after storge doesn't mean that the fuel system is not going to cause you big problems in the future. Link to comment
Skywagon Posted October 25, 2022 Share Posted October 25, 2022 Yep....what DR said. A bike sitting 5 years is going to require a lot of maintenance and parts replacements as he listed. Additionally brake cylinders, master cylinders----seals and o rings will likely be problematic. If it is rubber e.g. fuel lines, brake lines, vacuum lines, tires...count on replacing them. Nikasil cylinders are really tough. I have (in my past) pulled airplane nikasil cylinders that had sat for more than 10 years that looked new. Valves, yes...cylinders likely fine. Link to comment
Mike279 Posted October 25, 2022 Share Posted October 25, 2022 Living in the Northeast our riding season is almost over. A bike like that can be looked at quite closely in a heated garage over the Winter months. It would be easy enough to take apart and go through. So depending on your situation it may be a good deal or a nightmare. Link to comment
SANTA Posted October 25, 2022 Author Share Posted October 25, 2022 thanks for the reassurances, will proceed with caution. Link to comment
szurszewski Posted October 25, 2022 Share Posted October 25, 2022 If it’s really a good price and it’s running well now, I’d go for it. (Unless you really want the 1200.) It’s going to be almost all the same systems as the S, like you said. My ‘04 S had been just parked in a garage for some time when I bought it. The fuel system was mostly ok (I did replace the filter and u bend hose but mostly because I was already in the tank to look around), though the brake system was full of sludge. That’s not hard to sort either - other than the abs unit, which yours might not have anyway. Link to comment
SANTA Posted October 27, 2022 Author Share Posted October 27, 2022 i guess i really want the camhead, and functioning abs, i let it pass. Link to comment
9Mary7 Posted October 27, 2022 Share Posted October 27, 2022 If it was a neglected ABS 1150, you didn't want the headache. Link to comment
