cycdude6 Posted May 29, 2006 Share Posted May 29, 2006 My ABS light keeps blinking and won't reset. This happened after I removed and replaced the battery for servicing. Fuses are good, battery is fully charged. Checked the connections i could reach. Then I reset the ABS, it worked for a minute, the abs unit made a noise and the fault returned. Any ideas? Link to comment
DEF Posted May 29, 2006 Share Posted May 29, 2006 Bleed the brake system, front and rear including the ABS bleeder nipples. Link to comment
1fastjunebug Posted May 30, 2006 Share Posted May 30, 2006 What year and model are you having this problem on? Link to comment
Joe Frickin' Friday Posted May 30, 2006 Share Posted May 30, 2006 I assume this is the '98 RT listed in your profile. If so, click here, and go to page 71 and 72 to find out how to read the fault codes from the diagnostic connector under the seat (just behind the fuse box). Let us know what you find out. Link to comment
gottago Posted May 30, 2006 Share Posted May 30, 2006 I'm not sure if I understand your problem correctly but my ABS quit working and the lights were flashing indicating a problem with the ABS. We did this procedure (reset the ABS) on my 2001 GS and it worked fine. Round test socket located on top of battery. - ground pin 2 - switch ignition on - push ABS button for at least 8 seconds - release ABS button - switch ignition off and remove ground from pin 2 Hope this helps Link to comment
gottago Posted May 30, 2006 Share Posted May 30, 2006 I found this website where we went when we had the ABS problem. Maybe it will help: http://www.largiader.com/abs/absfault.html Link to comment
RaginCajun Posted June 1, 2006 Share Posted June 1, 2006 I had a similar problem after having just purchased a new to me 99 R1100RT. I brought it in and $xx later, they told me that I probably have a bad hydro unit...as realized by the diagnostic code. However, they were able to reset it, and now my ABS is back. They guy said he could reset it each time, or that bleeding the brakes might work. Hey, I'm curious. Someone mentioned reading the codes using the diagnostic plug...is there an easy way to read the codes without the handheld computer? Link to comment
Joe Frickin' Friday Posted June 1, 2006 Share Posted June 1, 2006 Hey, I'm curious. Someone mentioned reading the codes using the diagnostic plug...is there an easy way to read the codes without the handheld computer? Um...yes. Link to comment
cycdude6 Posted June 1, 2006 Author Share Posted June 1, 2006 The bike is a 1998 BMW R1100RT, ABS II. The abs does reset but immediately goes back off. My next step, I guess, is to check the abs sensors for proper gap (though I can't imagine why the gap would change!). After that I'm gonna tear the plastic off and start looking for disconnected or damaged wires. Also, I am going to try reading the fault codes as recommended by Joe and I'll pass on what I find. Link to comment
Joe Frickin' Friday Posted June 1, 2006 Share Posted June 1, 2006 The bike is a 1998 BMW R1100RT, ABS II. The abs does reset but immediately goes back off. My next step, I guess, is to check the abs sensors for proper gap (though I can't imagine why the gap would change!). After that I'm gonna tear the plastic off and start looking for disconnected or damaged wires. Also, I am going to try reading the fault codes as recommended by Joe and I'll pass on what I find. My advice is to try reading the fault code first, before you start inspecting parts; the whole purpose of the fault codes is to save you from having to inspect every part of the system before finding the problem. Link to comment
majordad Posted June 1, 2006 Share Posted June 1, 2006 I had a idea but preventing these kinds of issues or others when changing a battery and thought to bounce it out you guys. Whenever I change or clean batteries in my cars, I insert a 9 volt battery/adapter/plug into my cigarette lighter to prevent having to reset the clock and radio stations. Wouldn't something like this help keep the electronics in the motorcycle/on the dash as they were prior to changing the battery? Link to comment
bmwmick Posted June 2, 2006 Share Posted June 2, 2006 Probably won't hurt anything but it's a waste of time unless you are trying to retain the radio preset memory and the clock setting. The ABS control unit does not care if the battery is removed or not. Mick Link to comment
majordad Posted June 2, 2006 Share Posted June 2, 2006 okay, scrap that idea if the ABS isn't helped by it. Link to comment
cycdude6 Posted June 25, 2006 Author Share Posted June 25, 2006 I promised to get back with some results, so: Was unable to determine cause of fault using an analog meter, did not try the LED testing. Took bike to shop, where they determined fault #3, front wheel sensor. Ordered part. Link to comment
