Tom02RT Posted May 29, 2006 Share Posted May 29, 2006 Hello fellow sport-tourers ... I need your assistance. Recently I went from an old cell phone with the 2.5mm jack to the Motorola Razr which has a mini usb jack. Now I need to find a converter in order to plug into the AutoCom system. I've tried searching the internet and obviously I don't know how to do searches well as I can't find what I need. What would be ideal is a mini usb on one end and a 3.5 mm male jack on the other. That way I could plug this directly into the autocom. But I suppose a mini usb on one end and female 2.5mm would work as I could use the AutoCom cable and plug that into the female 2.5mm. What have you all done? Thanks in advance. Link to comment
topdal46 Posted May 29, 2006 Share Posted May 29, 2006 I have a Razr phone too, Is it not set up for Bluetooth only? Link to comment
steveknapp Posted May 29, 2006 Share Posted May 29, 2006 You need an Motorola USB-2.5mm adapter. There are two types I've seen. The eBay type.. http://cgi.ebay.com/Motorola-RazR-v3-SLV...1QQcmdZViewItem And the motorola version which I know exists but can't find forsale. Link to comment
Illini Posted May 30, 2006 Share Posted May 30, 2006 I've talked with a few folks who have advised the mini usb port is an input for charging only. Since the Razr is bluetooth enabled it does not have an output for headphones. check with autocom to see if they have a bluetooth hookup for your phone Link to comment
beemerman2k Posted May 30, 2006 Share Posted May 30, 2006 I have the same phone. The same mini-USB port for charging is also an output port for headsets that support the mini-USB connector like the one that comes with the phone. It would have been nice if they'd given the phone 2 such jacks, that way you can talk on the phone while it's being charged. Link to comment
Iron Al Posted May 30, 2006 Share Posted May 30, 2006 Since your phone is bluetooth capable, I'd suggest you get a Motorola HF800 bluetooth speaker. It has an external headset jack that you can plug into the Autocomm. It will ring through the headset and can dial out using voice dial. I got mine on eBay for about $20. It is also nice in that I can always keep my phone in my pocket and not physically attached to the bike. Link to comment
raiden1612 Posted May 30, 2006 Share Posted May 30, 2006 I use the motorola hf820 with my Razr. Rings in the helmet. only issue is water and I carry a ziploc for that. I used the supplied music lead to connect it to my autocom. I took the belt clip off and attached the holder with a ziptie to the handle bar. Just remeber to take it off the bike when out of view. Link to comment
jimwms Posted May 30, 2006 Share Posted May 30, 2006 Here are a couple of other sources for the adapter. Works fine with my autocomm. Accessory 1 Accessory 2 Link to comment
Heck Posted May 30, 2006 Share Posted May 30, 2006 Al- I just did this! Unfortunately, I cannot get enough audio volume to hear the phone thru the headset jack in the HF820. Have you heard of any solutions?? Am running Pro-7 with 56 (black box) splitting phone and a 58(red box) that brings in the GPS and Radar Detector....Sure would like a solution before I take off on a Saddlesore in about 2 weeks. Everything works perfectly except the volume. I have adjusted everything I can up with less than good results. Any Ideas Al? or anyone? Link to comment
steveknapp Posted May 30, 2006 Share Posted May 30, 2006 I've talked with a few folks who have advised the mini usb port is an input for charging only. They are wrong. The port can carry power, data, headset audio, and stereo audio. It would have been nice if they'd given the phone 2 such jacks, that way you can talk on the phone while it's being charged. No room! Link to comment
Tom02RT Posted May 30, 2006 Author Share Posted May 30, 2006 Thank you, thank you, Thank you, Thank you ... to all who have responded. I appreciate you help. Link to comment
nbooth Posted May 30, 2006 Share Posted May 30, 2006 Actually, does anyone have an auto-answer phone they recommend that has a broadband capability? Link to comment
Troper3 Posted May 30, 2006 Share Posted May 30, 2006 Tom, Hello, good question. TopGear makes a Razor phone connection cable. Your local dealer should have one in stock. If they do not they can order one for you. They are $49.99 or if you have a wired headset that you are not using. You can send it in and have one made. This should save you a little money but it will take longer to get(shipping back and forth). Link to comment
Iron Al Posted May 31, 2006 Share Posted May 31, 2006 Al- I just did this! Unfortunately, I cannot get enough audio volume to hear the phone thru the headset jack in the HF820. I'm running my HF800 through the gray connector on my Autocom Active 7. I haven't had any problems with the volume but then I use custom molded earplug speakers. Link to comment
steveknapp Posted May 31, 2006 Share Posted May 31, 2006 Actually, does anyone have an auto-answer phone they recommend that has a broadband capability? Define broadband capability? The folks who have V3Cs are happy with em, same for the V810. Both are EVDO. Not sure if verizon allows you to use em as modems. I could check on the auto-answer feature if you're interested. Link to comment
